I have a cal spa 3 years old. I turned off and emptied 6 months ago. Last night , I cleaned and refilled. When I switched the breaker on, I can get the spa temperature to registar and the light to work, but I can not get the water to circulate. My controls are light/water and Temp> located as a touch option. When I press for the water to circulate, I hear a ''click'' but no action. My spa is an F-series, 4 seater. Help
SOURCE: Spa Motor Hums
if it is a used pump, these have a tendency to have a little rust. just get some pump pliers and rock the shaft gently back and forth. then plug it back in.
David
SOURCE: I emptied my spa for
I would suspect that there is an air bubble trapped in the pump. Did you run the hose into the filter intake and confirm water was coming through the jets when you began filling?
