Hello! I have a Super Deluxe Zigzag III (I think) sewing machine. While working on a quilt today, the tension disc assembly popped off! There are 3 pieces...the dial with the numbers, the housing that fits into and a spring with the tension guide thing you put the thread through after placing it through the tension discs. I cannot for the life of me figure out how to get it back together properly. The instruction manual of course doesn't mention the assembly. Can you help?
Sorry but there is no way to explain how to re-assemble the tension mech on here, you need to be actually shown or have someone do it for you. It is very fiddly and needs to be exact, can I suggest you get in touch with a sewing machine tech who(at cost) will sort you out.
Sorry I cannot be of any further help.
Rob
Thank you, I did take it to a repair shop. It turns out that the tension assembly was inadequate and probably had been trying to fall apart for years. I spent 2 hours trying to fix it myself, then the repairman spent another 3 before he concluded that it was not able to be fixed. He installed a new tension mechanism, found a few other minor issues and repaired them, only charged me $40 and had it finished in 24 hours! :)
TENSION ASSEMBLY DIAGRAM FOR MODEL 921
I removed the knob to put oil on moving parts. Forgot which number dial was on when I replaced knob. help
