Question about Canon PowerShot S2 IS Digital Camera
My Canon S2 IS Powershot camera LCD screen turned black
I've had my Canon S2 IS Powershot camera LCD screen turned black.I have been in touch with Canon and it is like it will cost me 99 USD to repair it. Any helpful idea on how and where i can have it repaired without having to spend that much?
  • Canon Master
  • 4,738 Answers
A stuck shutter is another common failure mode for digital cameras, ESPECIALLY for the S2 IS (you should actually complain to Canon at 1-800-OK-CANON. If it is indeed a sticky shutter, they have been fixing this for free). The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help. Hope this saved you $99.
Posted on Apr 29, 2010
6ya staff
SOURCE:
MY CANON G10 DOES NOT SHOW AN IMAGE ON THE SCREEN ON THE BACK OF THE CAMERA?
Known issue!
G10 => Dead Black Sceen ! (only on screen infos): Canon PowerShot ...
https://www.dpreview.com/forums/thread/2639340
  1. Cached
Aug 13, 2009 - 11 posts - ‎4 authors My G10 is dead a few days ago, in a middle of a trip... (can't explain my ... Does the camera take pictures and can you download them to your computer? Then your sensor is OK and ... No cover on lens, and tried every display mode, you can trust me. ... (and even on, I will not have a permanent black screen). PowerShots can't do purple!?: Canon PowerShot Talk Forum ... 29 Dec 2013 G11 Date & Time Issue: Canon PowerShot Talk Forum: Digital ... 31 Jan 2010 G10's LCD dims when held in vertical position: Canon PowerShot ... 16 Nov 2008 G10 Can we adjust in camera parameters like sharpness for JPG ... 16 Nov 2008 More results from www.dpreview.com
A Simple Fix for a Stuck Shutter 'Do It Yourself Digital Camera Repair
camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
  1. Cached
  2. Similar
May 30, 2009 - Would not recommend trying to open your cameras to repair this ... Also turn off the LCD screen (press the DISP or DISPLAY button). ... For many Canon cameras this will be shutter priority (Tv) mode (for .... I got the image back in about 5 tries. .... My Cannon S2 IS had a black picture and I fixed it from your ...
Canon G10 screen is black
www.lionebra.com/canon...g10_digital_camera/q1947687-canon_g10_screen_black
  1. Cached
Canon PowerShot G10 Digital Camera - Canon G10 screen is black- ... with the menu,changed something and now the screen does not show image of anything. ... has problem in CCD Imager and this part will be replaced to get back picture. ... E18 my canon powershot A150, got the whole E18 problem, it turns on with the ...
Canon Powershot G10 image quality problems... I have had my Canon ...
www.lionebra.com/canon...g10...camera/q4217842-canon_powershot_g10_image_q...
  1. Cached
Canon PowerShot G10 Digital Camera - Canon Powershot G10 image quality ... They are not coming back with a completely blank screen as I can see the ...
Digital camera repair - Digicamhelp
www.digicamhelp.com > Digital camera care > Digital camera repair
  1. Cached
  2. Similar
Digital camera repairs can be expensive if not covered under warranty or a service advisory. ... When a sensor goes bad, images may exhibit some or all of the following: ... Hard reset for Canon compact cameras: this has worked for some Canon ... a blank LCD screen, a stuck lens or sensor or other problem that can't be ...
S2 IS "black screen *****" problem: a SOLUTION! ' Canon PowerShot ...
https://www.flickr.com/groups/26928900@N00/discuss/72157606903408401/
  1. Cached
  2. Similar
Aug 23, 2008 - My 1st Canon (film) camera was a TL and I'd probably still have it but ... The "change the batteries" problem: Does any S2IS *not* have the ... A couple of weeks ago i turned on my dear S2 IS and.. no image!! i could only see the menus .... Actually, I had to do it 3 times before the screen got back the image.
Nov 24, 2016 | Canon PowerShot G10 Digital Camera
Broken screen
If the camera is fully functional other than the screen, then yes the LCD screen can be replaced, you can order the part yourself from a Canon dealer if you wanted to do the job, or let them handle the repair with an estimate.
Jan 25, 2011 | Canon PowerShot SD630 Digital ELPH / IXUS...
Canon power shot S2 IS 5 mega pix camera it just shows a black sc
Your camera has the know issue of Stuck shutter, whichhappens after some time (weeks or months) thata camera is notused.
Unfortunately the repair of it requires a complete disassembly of the camera, including the lens, fix it, and then put back together everything.
Definitely requires th skills, tools and experience to do it, so it's recommended that a professional camera repair center is performing this type of repair.
If you look for a reliable and low cost repair service for it, you can look in ebay for such repair services.
Example, look for seller ID Great_items_2004 or with the keywords "Shutter black S2".
Best regards,
May 07, 2009 | Canon PowerShot S2 IS Digital Camera
Black screen when taking pictures
It's very possible that the problem is that the shutter is stuck, which is a known Canon issue on the powershot cameras, mainly on the S2 and S3 models, which it happens after some time (weeks or months) thata camera is not used.
Definitely requires the skills, tools and experience to do it, so it's recommended that a professional camera repair center is performing this type of repair.
Example, look for seller ID Great_items_2004 or with the keywords "Shutter black S3".
Best regards,
Nov 09, 2008 | Canon PowerShot S5 IS Digital Camera
Canon S2 IS
Best regards,
Jun 17, 2008 | Canon PowerShot S2 IS Digital Camera
Canon S2 powershot. Camera turns on but no pictures show up and cannot see through the viewfinder...it is black. Menus all work. What can we try?
First thing to try is that you didn't accidentally turn off the LCD screen. Turn on the camera, and press the bottom DISP on the back of your camera.
If that didn't work, the next thing to try is to take a picture while the viewfinder is black. Download the picture to your computer, and view it on the computer's monitor. Does this picture also show up as black. If so, then the camera's CCD imager has likely failed, requiring professional camera service to be repaired. If your camera was an S1 IS, Canon would fix this for free:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Unfortunately the S2 IS is not on the advisory list. If you wish to inquire of professional repair from Canon, please call 1-800-OK-CANON.
May 26, 2008 | Canon Cameras
Canon S2 1S
Best regards,
Apr 05, 2008 | Canon PowerShot A75 Digital Camera
From a similar solved problem: I have read of this problem (doing research before buying a Canon S2). Apparently it is a bad sensor and Canon will fix it for free if it's still under warranty (otherwise it will cost $119.00). and I have the same problem. Just got off the phone with Canon and have to send the camera to them. Repair takes ~2wks. Call them @1-800-828-4040 and follow the menus. Canon's site also addresses this for the S1 and others (but not the S2). Says heat and high humity can cause a connection to the sensor to come undone. Hope this helps.
Sep 29, 2006 | Canon PowerShot S2 IS Digital Camera
Canon PowerShot S2 IS Digital Camera Logo
518 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
