HP DeskJet 932c InkJet Printer Logo
Posted on Apr 29, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Orange ink light blinks. printer will not print.
Anonymous
Level 2:
Scholar:
  • Expert 118 Answers
  • Posted on Apr 29, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
118
Questions
0
Helped
38114
Points
237
turn on/off, unplug, plug in, should reset configs.
go to applications folder for your computer, dbl click printer icon for make of printer. check settings. print 'test document and clean cartridge heads', this should ensure proper printing formats.
lastly, go to web site of printer model and check site for trouble shooting if this does not work above. HP has an awesome trouble shooting site
hope this helps and good luck
5 Related Answers
Anonymous
  • Posted on Dec 24, 2008
SOURCE: HP Deskjet 5740 printer both orange lights are blinking and wont print
  • I replaced both carts with HP brand, no joy.
  • I cleaned the cart/printer connections, no joy.
An interesting aside is that if one or the other cart is removed, the appropriate LED goes out and the other blinks. At least some of the sensing circuitry sees the cart.
Anyone have a schematic of the cart/printer electronics?
Anonymous
  • Posted on May 30, 2009
SOURCE: HP desjet F2180 blinking orange light
pls tell me abt hp compaq d530sff mother board dive how to download ?
Anonymous
  • 72 Answers
  • Posted on Jun 17, 2009
SOURCE: inserted new cartridges..orange light still on
Try re-seating the ink cartridges. A lot of times, the electrical contacts on HP's ink cartridges do not make a solid connection.
Anonymous
  • 241 Answers
  • Posted on May 28, 2010
SOURCE: hp printer power light keeps blinking -- wont print any document
Turn both your printer and computer off then after a few minutes turn back on. This should cancel the print job.
Anonymous
  • Posted on Jun 15, 2011
SOURCE: 1320c Dell Printer has blinking orange error
This took me some time to find, and "the oracle" was of little assistance. However, if you visit the following link:
http://support.dell.com/support/edocs/systems/prn1320c/en/ug/1320c_en/section18.htm
and search for
"Clean the CTD sensor"
The solution provided worked for me.
If you still receive the error after trying this, open the side door (where the toner is) and hold the reset button down in the back until the unit turns off. Then hold the continue and cancel buttons while releasing the reset button. The unit will flash all lights after about five seconds at which point you can release the buttons. Then, close the door to the toner area.
Viola, I hope.
1helpful
What causes orange light to flash 4 times?
It is related to a badly installed or empty print cartridge: http://www.canon.co.uk/support/consumer_products/product_ranges/printers/pixma/error_codes/#1600
1600 - Orange light blinking 4 times Description:
The ink cartridge has run out.
Resolution:
  1. Lift the printer cover up.
  2. Identify the ink cartridge that has run out (the ink cartridge flashes quickly at around 1-second intervals).
  3. Replace the applicable ink cartridge and close the cover.
  4. Press the [Resume/Cancel] button on the device to continue printing.
If the above solution has not resolved your error, please contact your nearest Canon authorised service facility using the link at the top of the page.
1660 - Orange light blinking 4 times Description:
The ink cartridge has not been installed correctly.
Resolution:
  2. Check that the red lights on the ink cartridges are all turned on.
  3. If no red light is activated on a particular cartridge, check that the cartridge is securely positioned and adjust if necessary.
  4. Also make sure that the orange protective cap has been removed from the bottom of the ink cartridge.
  5. Press the [Resume/Cancel] button on the device to continue printing.
Originally the black ink would not print. replaced, primed, cleaned. nothing, the same problem, no black ink. Now I can't get the cartridge light to quite blinking. It is not steady orange, but a...
First off, if you touched the metal contacts on the printer or cartridge, you could damage or leave a film on the contact surface. Take it out of the printer, with a qtip dip in rubbing alcohol, squeeze out access, rub surfaces, air dry, and reinsert again. If still no ink, turn the print end up under the very hot water tap and run for 2 minutes. Dry and replace. It may do the trick.
1helpful
2answers
Reset. Orange light blinks several times. Then Green. Then orange several times, then... on and on. Cannot reset. All ink cartridges have ink.
count the number of orange flashes in between the green light. two flashes = out of paper, 3=paper jam, 4=empty ink tank, 6=print head not installed, 7=print head defective, 8=waste ink tank is almost full
1helpful
Hp printer power light keeps blinking -- wont print any document
2helpful
DeskJet 940c InkJet Printer: I have an hp deskjet 940c printer. The orange lig...
the moving ink frame is probably pointing to a symbol such as replace color ink( three dots on ink cartridge picture). Replace color ink. You are probably printing your black and white documents with colored ink--always select black or greyscale.
1helpful
Tank absorber full and lights blinking
The POWER Lamp Flashes Orange Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact a Canon service representative.
Note
Canon recommends that you call for service as soon as this error occurs. Once the waste ink tank becomes completely full, printing will no longer be possible.
Document is not printing
Press the feed button. If that doesn't work, turn the printer off, wait a few seconds, and turn it back on again.
Canon i950 won't print
try this Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960)
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
one by one
932C Constant blinking ink light
problem here is the orange light blinking- has ink in the cartridge- stopped printing in the middle of the page
k24674
Grand Canyon Tech
Grand Canyon Tech
