Windshield wipers stopped working after getting caught on windshield in heavy snowstrom when starting .. they were in up position when turned off Heavy snow and when restarting the car they were stuck in up poistion and stopped working.. can hear motor running.. can move wipers by hand
More than likely, your little wiper transmission isn't catching correctly. I had this issue with my sisters Buick. Open the hood. Remove the panel located nearest to the bottom of you windshield near your wipers. You should see a small oval or teardrop shaped cover, (approximately the size of a playing card) that you will need to remove to expose the wiper transmission. It just pops off. Turn your wipers on and see if the "tab" on the transmission catches to stop your wipers in the down position. Her's did not. I lubricated it slightly and with careful pressure, bent the tab just a bit. The wipers then caught at the appropriate time, closing the wipers correctly. Remember to replace the cover and the panel on your vehicle when complete. Ever onward! Hope this was helpful for your model as well.
With ya'lls perty white heavy snow,it made your wipers get unaligned,you will have to remove and reset.It's not good to remove snow from wipers when windshield is loaded,get a scraper or blower and go at it.Wish we got snow.
The windshield wiper circuit has an circuit breaker in it, under heavy load this breaker trips to protect the wiper motor, when the motor cools, the breaker resets automatically restoring proper wiper action.
At the base of the wiper arm there is a plastic cap,pop this off ,underneath there is a nut that holds the arm in place ,if it gets loose the post will turn inside the blade.Just turn the wipers off and tighten the nuts with the blade in the parked position.
Turn wipers on (veh in "on" or "acc" position)
Disconnect the electrical connection at the windshield wiper motor (located in the engine compartment on the fire wall) and check for voltage. If you have voltage, there is a good possibility your windshield wiper motor is bad.
You may also: Disconnect the electrical connection at the windshield motor and run a heavy gauge wire directly from the positive side of the battery to the motor. If you get the windshield motor to come on. There may be only a wiring (short) problem between the relay and the motor.
Let me
It sounds like the the circuit board has gone bad and does not know where the base is any more so it will stop at the middle or the windshield. Auto Zone should have a new board if it's replaceable like the GM products. Good luck and hope this helps, In the mean time you can always turn your wipers on and pull the fuse out when it's at the down position so it's not up.
Windshield Wipers Continue to Run When Turn Signal and Windshield Wiper Switch Are Turned OFF
Damaged turn signal and windshield wiper switch .
Damaged windshield wiper motor .
Damaged windshield wiper control module.
Pin Number
Circuit
Circuit Function
57 (BK)
Wiper Motor Ground (Park)
28 (BK/PK)
Wiper Module to Wiper Motor (Park Switch)
65 (DG)
Wiper Motor Power (Park Feed)
61 (Y/R)
Wiper Motor Common (RUN)
5
56 (DB/O)
Wiper Motor LO
6
58 (W)
Wiper Motor HI
Windshield Wiper System
The windshield wiper system consists of :
Windshield wiper motor (17508) (F-type).
Washer system.
Windshield wiper control module.
Turn signal and windshield wiper switch (13K359).
The windshield wiper control module is:
Located at the instrument panel fuse panel.
The windshield wiper motor is:
Attached to the cowl top extension (021A36) .
Connected to windshield wiper mounting arm and pivot shaft (17566) .
The turn signal and windshield wiper switch features a:
Rotary wiper switch.
Push type washer actuator.
OFF/Low/High Speed
Has a two-speed, permanent magnet, three brush electric windshield wiper motor .
The windshield wiper motor has a brush rigging that permits selection of low or high speed.
When the turn signal and windshield wiper switch is in the LO position, the common brush and the blue/orange wire brush are used, and the windshield wiper motor operates at low speed.
When the turn signal and windshield wiper switch is in the HI position, the common brush and the white wire brush are used.
In HI position, electric current will bypass a portion of the armature winding causing the windshield wiper motor to operate faster.
When the turn signal and windshield wiper switch is moved to the OFF position, the windshield wiper motor will continue at low speed until the park switch outer contacts open.
When the park switch contacts open, the windshield wiper motor stops in the park position.
Interval
When the turn signal and windshield wiper switch is in the interval position:
The wipers make single wipes separated by pauses.
The rotary switch is on the end of turn signal and windshield wiper switch .
The length of the pause can be set from approximately 1 to 17 seconds.
Length of pause decreases as the rotary switch is rotated away from off.
Length of pause increases as the rotary switch is rotated toward off.
While in the interval wiper mode:
It is normal to hear a slight click at the beginning of each on/pause cycle.
NOTE: When using interval wipers, the first wipe may not occur until after a pause of up to 17 seconds.
1) Remove the driver side wiper (arm & blade). 2) Start the car and turn on the wipers. 3) When the passenger wiper is straight up and down .. turn off the car. This leaves the wiper in position. 4) Re-install the drivers side wiper and put it back on so its position is the same as the passenger - making them parallel
