Hi van derb
You would need to convert MOV file into a format which PS3 understands.
This can easily be done with a simple conversion tool such as the 3herosoft PS3 Video Converter.
1) Download and install 3herosoft PS3 Video Converter. Once installation has completed, launch the program.
Step
2 ) Click "File" and then "Add" from the top menu of the 3herosoft PS3 Video Converter program. Browse to the folder and location of your MOV file. Select the file that you want to convert to PS3 format and click "Open." Once selecting the file, it will be added to the conversion list.
Step
3) Edit the file as desired. Modify fields under "General" in the upper left-hand corner of the program window. Changes can be made to video size, duration, frame rate, buffer size and more.
Step
4) Click "Convert" button (red circle) to convert the MOV file into PS3 format. Locate the converted file and transfer it to your PS3 for playback.
You can download this software from following link.
http://download.cnet.com/3herosoft-PS3-Video-Converter/3000-2194_4-10909133.html
Please rate, as this will help us know whether solution was helpful or we need to improve on it.
If not resolved you may post a comment and let me know, so that I can research and provide you with a better solution.
You may need to convert the mov files to other formats that ps3 supports such as mp4. You could use Leawo Video Converter to do this which can also play the mov files.
The following is a step by step guide on how to convert MKV to PlayStation 3 supported video format at http://www.bigasoft.com/articles/how-to-play-hd-1080p-720p-mkv-on-ps3.html, it also applies to convert and play MOV on PS3
This guide applies to:
Convert 720p MKV to PS3 supported format so as to stream 720p MKV to PlayStation 3 for playback successfully
Convert 1080p MKV to PS3 compatible format to stream and play 1080p MKV on PS3 with ease
Convert other HD MKV files to PS3 format to stream and play MKV on PS3 successfully
Convert MKV to PS3 supported format as well as add subtitle to the converted MKV video
Convert
other video formats like FLV, BIK, MOV, AVI, MP4, MPG, F4V, ASF, WMV,
MXF, WTV, AVCHD, VOB, DV, MOD, TOD and more to PS3 supported format for
easy playback
