Rheem 40 GAL ELEC TALL Water Heater 6YR SC 82VH402 Logo
Posted on Apr 28, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lose of hot water at times
Haft to reset the reset button time and time again than I will have hot water for a time
Anonymous
Level 3:
  • Rheem Master 43,501 Answers
  • Posted on Apr 28, 2010
Anonymous
Rheem Master
Level 3:
Answers
43501
Questions
0
Helped
10843640
Points
101584
If you keep kicking the reset you have a thermostat that is bad...it could be either the top or the bottom one...but you will have the check and see if it is switching to the bottom element or not...if it does switch to the bottom it is the bottom t-stat bad, if not then the top one is bad...
heatman101
1helpful
I have norton tankless water heater, and the reset keeps getting tripped... what can cause this?
It can be the breakers in your house or the reset button is malfunctioning
1helpful
I have no hot water in my home i can not locate the reset button
The reset button is located on the top thermostat, on the heater you will see a acess panel with screws in it to remove the thermostat and element is behind this panel. Once removed the top thermostat should have a red button to press to reset heater.
If it resets then wait for a little time for hot water. If this doesn't work then it could be the elements are in need of changing.
I have a Reliance 501 model # 5 30 2srs4. I had to reset the unit after waking up to cold water. The water heated up in no time at all but the water was super hot. So hot it triped the reset button again....
No, the top thermostat will always heat first and then it should dwitch the power to the bottom one after the top of the tank heats...this is to get you hot water faster...
The top thermostat is bad and is not shutting off or switching....
Replace the top thermostat/reset combination and you''l be good!!
Check out this tip..
How to replace the Thermostat and Element for
Electric Hot Water Heater
heatman101
1helpful
Water is not hot
If your water has NO hot water, then click circuit breaker
Next, click red reset button.
Turn off power.
Open cover on water heater.
If heater has 2 covers, open top cover
After re-seting water heater, insulation must be put back over thermostat to prevent cooler air from affecting thermostat.
1) Reset button is a good starting place to check water heater.
Reset clicks off for a number of reasons, including overheated water.
2) Reset will not reset, then replace thermostat.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
3) Resets clicks on, but clicks off again later, you should diagnose the problem.
Clicking reset is not a hazard
Click the reset as often as you want until you have time to diagnose.
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
4) Reset is not tripped, and you still do not have hot water:
Then use tester on top two screws (T1 - T3 screws -or- 1 and 3 screws) of upper thermostat to check if you have power.
If you have power, then replace thermostat.
If problems continue, a full diagnosis is needed as per the link above
If you need more help, add a comment and I will respond
Hot water gets too hot trips off at tank then water gets cool and i push reset button and water gets hot again real hot thentrips off again
It's time to replace your thermostat. Instead of maintaing the correct water temperature, the water is getting so hot it is acivating the safety circuit breaker. If this breaker were to fail, you could have a devastating explosion
My water pipes froze thursday night so friday night when i went to bed i left the tubs hot water turned on and they thawed out about 2am i got up and turned the tub faucets off the water was hot at that...
you probibly ran the hot water tank out of hot water shut off the hot water comming out of your fausets for a few hours and check it again u could also try to reset your tank by pulling off the front cover and hitting the reset button and my last thought is sadly you burnt out your heating elements and they need to be replaced good luck man
Residential electric hot water heater throwing br
If you reset the water heater the first time you were without, Then odds are it is the water heater. probably an element went back. If the power off check for continuity.
Please rate this response and Good Luck, Phil
Top Rheem Water Heaters Experts
Mike Cairns
Mike Cairns
Sean Wright
Sean Wright
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
