I tried to remove mold and mildew on my freezer rubber gasket and it wont come off. i used vinegar, baking soda,clorox. what do u rub on gasketafter to replace on thank you i need help bad.
My name is Peter. I am a retired field service refrigeration technician.
Putting in the wrong water filter will not effect the smell in your refrigerator. At times the granules in a water filter will break down and get into your water dispenser and ice cube tray. This should not create a bad smell, just cloudy water.
Your plastic liner in your refrigerator has pores and holds odor. You have something in your fresh food section or freezer that is spoiled. Your fresh food section receives cooling air from your freezer. If you have a spoiled product in your freezer you will not smell it because it is frozen. But, as the cooling air goes into your fresh food section and cools down you will smell it.
Find the bad product in your freezer and discard.
With a 50% solution of white vinegar and water wash the plastic liner.
Now you can put a tray of baking soda in your unit, until you purchase deodorizers based on temperature requirements, one especially designed for the freezer section and one for fresh food section. These deodorizer are about $12.00 each.
Hello nnwaldron - Try the following suggestions below; if it prove to be ineffective then the liner will need replacing.
1) Dip a moist, soft toothbrush in a box of baking soda. Very gently, in the direction of the stainless grain, rub back and forth on the appliance. The mild abrasive action will get into the grain without damaging it. You can use your finger (instead of a toothbrush) for even better results.
2)Rinse the baking soda off with a warm, damp (not wet) paper towel. Dry thoroughly. You may see or smell rust on the paper towel or toothbrush. That means it is working!
3)Finally, dry the appliance thoroughly. You don't want to leave any water that could cause more rust.
Well an old remedy is to put a box of opened arm and hammer baking soda in the freezer and fridge to keep it from having bad odors.If that doesn't work you can try some charcoal it is perfect for absorbing odor, just don't use the matchlight kind or it will smell like lighter fluid.
Your problem could be caused by a clogged drainage tube. even though you may have removed the ice it may still have a clog. my suggestion would be to take all of the contents out of your fridge and let it sit unplugged for atleast 24-48 hours with the doors open this will eliminate any left over ice that may be clogging your drain tube. if this dosent help then you may have a defrost heater problem, or possibly a defrost termination switch problem. as for the smell i know that vinegar works well for getting rid of odor. ther eis also a product you can purchase called fridge aid, it is a charcoal based air purifier and should work well.
Personally, I have used bleach & warm water solution to scrub out interior.....then rinse thoroughly....followed by drying thoroughly. Now place a box or two of Baking Soda in freezer (depending on size) and close.
Hi there
i have to give that a wow !!! any way if you can get some clr and wipe it down real good and leave it wet it overnight that has helped us in some of the apartments that we clean well good luck and let me know how this does best regards mike
