DLP/mirror chip is going bad. A common problem on Sammy TVs after 2-3 years. Chip is user replaceable (try samsungparts.com or ebay) for about $150-200. Sammy was (last year) repairing the DLP White Spot problem for free. You MUST talk to ECR (executive customer service) to even think about getting that consideration--forget the standard CS people. Don't know if they are still covering this out of warranty in 2010.
Is the color wheel the same as the DLP chip. I have the white spots problem on the Samsung HLS5086W.
Ur light engine is dead.This problems,very common on this DLP tv model.About one or two year this problems will occur again,again.Samsug now this defect in the design,but never recall this tv model,after nomorous customers compalain about this problems.Sorry that all u do,it to change the Light Engine to solved this problems.
SOURCE: Numerous white spots on Smasung DLP TV
You will actually get white and black dots , the black ones are tougher to see because of the color in the background , within 2 months youre picture will be fully covered with dots....I went through the Samsung website troubleshooting flow chart , and it led me to a bad Digital Micromiror Device , or DMD board . What is actually the problem is the DMV chip connected to this board . Inside this chip are 3 million tiny mirrors ,and when they physically get stuck , they either show black or white instead of a color . Samsung will not tell me the part number of the chip , they will only offer to send a service tech to my house .
SOURCE: I have black spots on my samsung dlp tv
I had the same problem with my Samsung DLP tv a couple of weeks ago. I had to clean the lenses, mirrors and the DMD sensor to fix it, you must remove the rear cover to do this. If the mirrors and lenses were cleaned but the spots were still there, the final thing to do is to clean the sensor chip on the DMD board. It is located under the heat sink behind the small fan in the lower center of the rear of the TV. The DMD board will have to be removed to get to the back of the sensor. All you have to do is blow some dry canned air across it to remove the dust, do not wipe it with anything. The repair is somewhat complicated and you will probably have to realign the picture by adjusting the position of the DMD board when finished.
If your Mitsubishi TV has white spots in the picture , you can call Mitsubishi @ 1-800-332-2119 and request a free DLP Chip to fix the problem. They will send the New DLP Chip at no charge to a TV Tech in your area to install it for $200 flat rate. That is about a $250 savings if you had to pay for the chip . Call them with your TV's Model number and serial number and let them know when and where you bought the TV.
It saved me some hard earned money and now my TV is like New !
