How to change the oil and oil filter on my toyota echo and what sort of oil to use
Toyota recommends 5W-30 and if you look closely you should see it printed on the oil filler cap itself. I have been changing my own oil like over 25 years and equally important if you want to keep your Toyota Echo engine in good running condition is hidden under a silver cowl that has like 10mm bolts you need to unfasten this metal cover on order to get a oil filter wrench on the actual oil filter. By the way, hopefully you are replacing it with a genuine Toyota oil filter as they are relatively inexpensive like $3 to $5 and removal counterclockwise is probably the most difficult part of an oil change, besides dumping the dirty oil into a container and cleanup to me is the filthiest part- but hey you saved like at least $10 or more by Doing It Yourself...
Hope the Above Info Helps!
Testimonial: "Yeah, that was great, just the info I needed with a few tips as well. Much appreciated."
