You're right..This happens often when one changes the battery.Here's what to do :
The ERR message can only be corrected by holding in the DISP/MENU and STOP buttons for two seconds, which results in ALL the material on the recorder being erased. It will say (FOR) for a few minutes while it is erasing everything, then will work again. Solution found at http://www.amazon.co.uk/Olympus-VN-2100-Digital-Recorder-microphone/dp/B000V3NTEU
I had the same problem with my Olympus VN-5000. I found a solution, which appears to reformat the memory (ERR means memory error). Try to press the STOP and DISP/MENU buttons at the same time for about 2 seconds, and then the display should show "FOR". It will supposedly erase the whole memory, but will at least make the device usable again! I hope this solution works for your model.
I had a similar sounding problem my Olympus VN-5000. I would turn it on, it would show "CHK" for a few seconds, and then "ERR." This persisted despite fresh batteries. The "ERR" message reportedly means a memory error. I found a solution, which appears to reformat the memory. Try to press the STOP and DISP/MENU buttons at the same time for about 2 seconds, and then the display should show "FOR". It will supposedly erase the whole memory, but will at least make the device usable again! I hope this solution works for your model...
The ERR message can only be corrected by holding in the DISP/MENU and STOP buttons for two seconds, which results in all the material on the recorder being erased. It will say (FOR) for a few minutes while it is erasing everything, then will work again. Solution found at http://www.amazon.co.uk/Olympus-VN-2100-Digital-Recorder-microphone/dp/B000V3NTEU
yes the above solution ie by pressing "STOP" button and "DISP/MENU" button at a time is solved my problem showing "ERR" in VN 2100PC olympus voice recorder
I had the same problem with my Olympus VN-5000. I found a solution, which appears to reformat the memory. Try to press the STOP and DISP/MENU buttons at the same time for about 2 seconds, and then the display should show "FOR". It will supposedly erase the whole memory, but will at least make the device usable again. I hope this solution works for your model!
