2003 Hyundai Tiburon Logo
Posted on Apr 26, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hyundai tiburon 03 2.7cyl
Car idles and will go ok, but as soon as you hit the gas hard it wants to bog down. Went to auto zone they put the code scanner on it and the codes for oxygen sensors bank 1 upper and bank 2, i have replaced and the check engine light wont go off, what else could be the issue.
Anonymous
Level 3:
  • Hyundai Master 3,640 Answers
  • Posted on Jun 02, 2010
Anonymous
Hyundai Master
Level 3:
Answers
3640
Questions
6
Helped
1674539
Points
10518
Have light turned off with scanner, or drive it a few miles to see if it goes off. just because the sensors have been changed the pcm thinks there is still a problem and keeps light on. turn off with scanner.
1helpful
3answers
99 Hyundai Accent changed altenator, battery goes dead, idles terrible, bogs down when gas is pressed. Please help
That is the good question. What I would do go to auto zone and check for the code it is free. Clean throttle body and changed fuel filter. Tune up, could be plugged up catalyst converter.
I have a 2003 Hyundai Tiburon Gt.When im coming to a stop and Im in neutral my car idles high.I can rev it up it drops back down to a 1,000 rpm's or where it should idle at.
Hello
The engine and transmission in this cars drivetrain are fully electronically controlled by a computer called the PCM (Power Train Control Module). Whenever a problem like this occurs the computer stores a record of the problem in the form of a fault code in its memory, to read these fault codes you must have the systems memory scanned with a special tool. Once the fault code(s) are read you then must perform the appropriate diagnostic testing to find and resolve the problem(s)
1helpful
I own a 2003 hyundai tiburon my check engine light came on I have 160000 km on it then the light went of do you know what the problem could be
its could be an 02 sensor. they are very wierd when they start goin bad your check engine light will do that for prolly another month an then it will stay on it causes your gas miliage to go down alil but thats it there about 60 bucks a an auto zone or parts witch every you go to same price.
My saturn vue is bogging down when i give it gas like it is starving for fuel ?
Start with the simple and replace your fuel filter, air filter and clean your MAF sensor. You can buy and MAF sensor cleaner at Auto Zone and the fuel filter also. While your there Auto Zone can scan your Saturn for any DTC codes that my be causing your engine performance issues, Auto Zone scan free of charge and if there is any DTC codes. They can give you the information to what needs to be done to get your Saturn running 100% again soon.
Thank you for using fixya and good luck. Keep me posted.
Its a 2.2 ohv and it runs like it has a bad miss it idles funny and kinda bogs down when i hit the gas but once above 2000 rpms it runs decent until about 3800 rpms then it sometimes starts to backfire
You didnt say if the check engine light is on? Take it to auto zone or advance auto parts store and they will plug it into diagnostic computer and let you know what sensor is bad for free. My guess? manifold pressure sensor. Good luck, dont forget to rate
3helpful
4answers
''Malfunction Indicator Light''
they just hired some ******** college graduate to confuse normal people.
you can take your car to Autozone and they will check your codes for free,one of the sensors on the car did not respond fast enough for the computer,have the code cleared before doing anything to see if it returns.
your car is not running pollution free.or fuel efficient
2answers
Car jerks while taking off; changed fuel filter
get a scan tool to retrieve the dtc (diagnostic trouble code).
you will get a misfire code.
p0301 for cyl 1
p0302 for cyl 2 and so on.
i can't recall if that engine has plug wires or coil on plug but if its coil on plug replace the coil corresponding to the cylinder misfire
Have a 2001 tiburon showing engine light went to auto zone had codes p1624 p0733 p0734 p1624 bblow cooling fan relay cicuit fault probable cause BB1open or short circuit condition BB2 poor electrical...
Take/Tow your vehicle to an authorized Hyundai dealership and pay the diagnostic fee... they will tell you exactly what the problem is and the cost of parts/labor to fix it... at least this way you'll know what the problem is and what's required to fix it.
Change everything indcluding whole fuel system.idles great but as soon as i hit the pedal it chokes an bogs down
Check for 30 lbs. of fuel presure is present in fuel rails, bring the vehicle to Auto zone to have them hook up the OBD II code reader to check for strored codes.
Top Hyundai Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Hyundai Expert? Answer questions, earn points and help others
