Question about Marantz Audio Players & Recorders
How do I record directly to CD on a marantz CD recorder model CDR310
    New Friend:
  • 95 Answers
SOURCE:
Can i transfer information from the recorder to my computer? marantz model cdr420.
Depends on your PC and its audio capabilities.
http://www.zzounds.com/item--MARCDR420
It has analog line I/O, and SPDIF digital I/O, and USB 2.0, allowing you to connect the CDR420 to virtually anything in the world.
Feb 10, 2011 | Marantz CDR420 CD Recorder
Marantz CDR-510: Playback is good , recording is distorted
If this brand of media is new to you and the symptom is unique to it, I'd try a different brand.
Monitoring during record would never reveal media problems as there is no immediate playback after record as on old-school 3-head tape recorders.
I've had similar intermittent problems and I never could find a pattern to it except that it always seemed to be on low-end media. My best advice would be to try to find a pattern in your instance and make a change that avoids it. Then publish what you learned for us.
Good luck.
Mar 14, 2010 | Marantz CDR510 2-Disc CD Recorder
I am looking for a voice recorder that will record then burn directly onto a CD. This device is separate from the computer. You can take it anywhere and then burn whatever you've recorded. I've seen this...
Check out this link below for a unit you are looking for. This will help you with what your looking for. Just copy and paste into your browser.
http://www.shopmartel.com/New-Marantz-CDR310-CD-Recorder-w-2-Free-Microphones-P68C1.aspx
Hope this helps, let me know if I can do anything else for you.
JimmyC
Oct 09, 2009 | Audio Players & Recorders
CAN,T DETECT CD IN BURNER TRAY
laser failure on the recording side is very common on marantz and philips cd recorders.
they're well known for it.
so it's most definately the laser in your case.
hope this helps.
Jun 19, 2009 | Marantz CDR500 2-Disc CD Recorder
Marantz CDR310 Will not keep changes to settings when powered OFF/ON Keeps resetting to default. New CMOS battery? Units only over a year old. Any ideas thanks!
There is no battery in these units. I will check the service manual tonight and try to get yu a detailed response.
Dan
Feb 26, 2009 | Marantz CDR-310
Laser is malfunctioning on my Marantz CD Recordable DR6000
the laser in your DR-6000 is exactly the same as what's in the philips cdr-775 and cd-r-770.
a brand new laser for these are very hard to get hold of and are very expensive. personally i would look out for the above philips models on ebay for less money then take the whole mechanism out and unscrew the servo board and then fit the marantz servo board in place of it and fit it back into your recorder.
i have done this on numerous occasions with no problems.
hope this helps.
Feb 26, 2009 | Marantz DR-6000 CD Player
Marantz pm 7200 integ.amplifier
Dear Sushant,    I do not think your use of an equalizer has caused any problems.  I will explain the proper use of the source/direct button.  This button's function is to monitor the output of a recorder connected to the record outputs of your amp.  When this button is pressed on the sound going to the speakers comes direct from the "source" (cd, radio tuner, phonograph etc.) when in the off position you can monitor the recording of whatever source is being recorded via the tape deck.  This switch must be off to record through the amps record outputs.    To test this, put a blank tape in the tape deck, choose the source as phono and place the dec in record/pause.  With the source direct button pressed on you should hear a change in volume when moving the amp's volume knob only.  When source direct is off you will be able to hear the output of the tape deck, so adjusting the tape deck's record level will also affect the volume coming out of the speakers.  more record level in/ more level out.!    Below is copied from page 9 of your user operation manual for Marantz's explanation of the source/direct button.  image.tiff
best of wishes, Michael Mittelsdorf
Jan 05, 2009 | Marantz PM7200 2-Channel Amplifier
CDR is not working
have a look on ebay for a cheap working donor recorder as spares are very expensive and very hard to get hold of.
i'm guessing your recorder either doesn't read discs, or it won't eject? which is very common and means either the servo board is faulty or the laser.
The following recorders i know off hand for a donor mechanism are:
MARANTZ DR-6050
PHILIPS CDR-775
PHILIPS CDR-770
if it proves to be just a faulty laser, all 3 of the above have the same laser unit.
if it proves to be a faulty servo board, all 3 have the same servo boards except if you fit one out of a philips model it will show 'PHILIPS CD RECORDER' on the display at power up but will still work nontheless.
obviously if a marantz is found it will show 'MARANTZ CD RECORDER' as normal.
hope this helps.
Aug 27, 2008 | Marantz CDR500 2-Disc CD Recorder
254 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
