Question about Pramac GBW30P Encl Diesel Genset w/Perkins Eng
How ican fix the high temprature problem - Pramac GBW30P Encl Diesel Genset w/Perkins Eng
    Novelist:
    Habit-Forming:
  • 118 Answers
First, the reason for the diesel engine temperature is too high
1. There is too little water leakage or cooling water;
2. The fan belt is too loose; the fan blade angle is not installed correctly or the fan blade is damaged;
3. The pump is worn, leaking or its pumping capacity is reduced;
4. The internal combustion engine runs for a long time under low speed overload;
5. The thermostat fails (the main valve cannot be opened); the injection time is too late;
6.The water pipe is blocked; there is too much scale deposited in the water jacket, and the heat dissipation is poor.
1. First check if there is water leakage in the internal combustion engine and if the water tank is short of water, then check the tightness of the fan belt. If the fan belt is not loose, check whether the fan blade angle is installed correctly, the fan blade is damaged, and the pump wear and pump Water capacity.
2. Check whether the internal combustion engine is transported for a long time under low-speed overload. Whether the injection time (or ignition time) is too late, the outstanding characteristics of the injection time (or ignition time) of the internal combustion engine are: the exhaust sound is loud, and the exhaust gas is exhausted. Black smoke, the machine is running weak, and the power is obviously reduced.
3. Check if the internal combustion engine thermostat is malfunctioning. The characteristic of the thermostat loss is that the temperature of the cooling water inside the internal combustion engine is high, and the temperature of the water inside the radiator is low. At this time, the temperature can be taken out of the internal combustion engine, and then the engine is started. If the water temperature of the internal combustion engine is normal, it can be determined that the thermostat is ineffective. If the water tank pipe is partially blocked, the internal combustion engine water will rise too fast.
4. If the scale deposit in the radiator cooling water jacket is too much or the water distribution pipe does not have the function of water separation, the cylinder block is touched by hand and there is uneven heat and cold.
Posted on Jan 22, 2019
    Problem Solver:
  • 8 Answers
See if the water is circulating round the engine and alse try and flush the radiator and also be sure the termostat is working well because a bad termostat will stop the coolant from reaching the engine block.
Posted on Jun 04, 2011
  • 5,603 Answers
Water level, good thermostat, good water pump, fan working? All things to check.
Sometimes an airlock will prevent water circulation
ALSO verify your temp gauge and sensor is working correctely. A failure of these may appear as high temp and even shut machine down if the sensor is bad.
Posted on Apr 27, 2010
SOURCE:
How i fix the heater unit problem?
Please change the temperature sensor thermistor.
Oct 08, 2015 | Canon Office Equipment & Supplies
How long should the compressor stay on? mine stays on for (5) minutes,then stays in fan-mode
Kindly check your temprature settings and ventilation of outdoor unit. Your compressor is getting hot either due to low ventilation or your temprature settings are too high to cool.
Sep 06, 2014 | Haier HPF12XHM-LP Portable Air Conditioner...
R 1 running hot with water temprature light comming on at high speed
check coolant level , elec fan , therostat and if engine is boiling and bubbling wen at running temp ! if ok then mite be a sensor ! P...
Dec 22, 2013 | 2007 Yamaha YZF-R1
High temprature
Mid way is ok, but u need check thermostat, cheap to replace, also check rad is not blocked with insects, oil ok? Water cap tight? Turn on heat full in car see the temp drop, water pump can be on way out
Apr 05, 2013 | 2006 Nissan Armada
Temprature problem
fans arnt coming on check your relay fuses and go from there
Aug 17, 2012 | 1984 Toyota Corolla
My Gigabyte M55SLI-S4 motherboard has a fan on it, not the CPU fan, that is starting to go bad. When looking at the motherboard diagram the fan is in the nForce4 SLI slot. What is this fan and what can...
Please follow the temprature from the BIOS Genearraly for p4 or duel 50 to 75 degree c.if you dont use original fan that you can not see. becayse mb driver can nort recoknise yhe device .Only it will be create problem when cpu generate high temprature due to genune fan. Your pc switch over
automatily.again & again .Then you must use the coller master or any other branded fan.
hope it will help you
Nov 27, 2010 | Gigabyte GA-M55SLI-S4 Motherboard
Temprature control
I suggest turn it to lower temperature, so that water won't drip down. You can get rid of the hardness by keeping those things out of the unit for about half an hour before using, so that it may lose some coldness and become soft.
Jul 05, 2010 | Fisher and Paykel Active Smart® E522BR...
It shuted down on it own and it doesnt display or
problem with mother board the tempratur Goes high the machine goes of.
to refix the procceser Fan, Apply paste on the prrocceser, reduce tempratur U R machine working normaly,
Mar 15, 2010 | ASUS A7S266-VM/U2 Motherboard
Error 5200 and error 5700
hi there
error 5700 is for your asf senser error clean or changing will fix this error.
error 5200 is for printer head temprature rissing high it may be by printer head or logic card.
Aug 15, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Asus P4B 1.7 mhz P4 motherboard restarts every 10-15 minutes...
Check the CPU temprature from the BIOS. Sometimes if the CPU overheats the system will automatically reboot. High CPU tempratures goes form (60-70). You can also monitor the fan speed and cpu temprature using this utility
http://www.almico.com/speedfan.php
Oct 27, 2008 | ASUS P4B-M (P4BM1400WOLTINY) Motherboard
Pramac GBW30P Encl Diesel Genset w/Perkins Eng Logo
295 people viewed this question
Top Pramac Electrical Supplies Experts
Marvin
Marvin
Lawrence Oravetz
wadingriver
wadingriver
Are you a Pramac Electrical Supply Expert? Answer questions, earn points and help others
