InFocus IN24 Multimedia Projector Logo
Anonymous Posted on Apr 26, 2010
My projector has little white dots that appear on a black or dark background, I've replaced the bulb and still have the same issue.I've read someone say the something about cleaning the light engine, is that possible and how hard would that be for an infocus in24 projector?
  • Anonymous May 11, 2010
    That fixed the problem, the spots disappeared. Thanks!
    That fixed it. Thanks!
Anonymous
Level 2:
Champion:
  • Expert 269 Answers
  • Posted on May 06, 2010
Anonymous
Expert
Level 2:
Champion:
Answers
269
Questions
Helped
105480
Points
416
Take off the front bezel, then remove the screws from the lens,pull the lens out and blow it out with compressed air. Do not touch the mirror or magnifier inside. If this doesn't get all of the blemishes, then you will have to remove the top cover and then the top silver part of the engine and blow it out from the top.
The image has little black and white dots everywhere. What is the problem?
1,white spots appeared on screen,means the DMD chip is broken,you need a new DMD chip.we supply the DMD chip
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
1helpful
2answers
Black and white dots on screen
Hi Emmanuel,
I think your projector lamp and LCD area is dusty.
please use pressurized air can and clean the area.also check the dust filter.
do it carefully.
regards,
nuwan
Lots of dots on the screen. In light areas they are black dots, in light areas they are dark dots
we supply the new DMD chip,it's life is 6 years, and the price is USD200
Have a nice day!
Jerry
Lampdeng Limited
2helpful
I have nec np200 and there's a lot of dots appeared on the screen. what seems to be a problem
I have 2 NP-200 projectors installed in a school which show white dots on a black background and black dots on a white background. This is caused by the DMD chip losing pixels. Only solution is to replace the chip, I'm researching now if that i an economical solution.
Black dots projected on my 3m scp716 projector
Actually, this is a known issue with this specific model as 3M has acknowledged. We bought 4 of these and 3 have had to be replaced in 3 years because of this exact issue. It requires the mainboard to be replaced and it is almost as expensive to do this as to buy a new unit. 3M has been know help to us on this even through we bought the entire setup (Projector, Arm, Smartboard) and spent over $15000.
2helpful
2answers
Light bulb
White dot for DLP Projector TV is not because of the light buy. It is caused by aging DLP chip ( DMD Chip.) Your TV DLP Part should be the following image:
Check the post how to place it diy
1helpful
I am getting white spots that are appearing on the display image. It started out with one but now there's more every day. Is this fixable? Is there dust maybe ibside the lens? Is the bulb going? The...
I feel Most of DLP's getting this issue. Please tell me If the black & white dots are blinking....
To see it you need to put very clearly focused A4 sheet. If some dots are blinking .... most of time DLP chip is bad or getting bad.. IF can please upload a very clear picture......
2helpful
4answers
Help! Our Optoma DLP projector is about 6 months old. It started with one white dot on the screen. It has since mulitplied to be at least 20 white dots all over the screen and now some black dots are...
Your DMD chip or DMD driver need to be checked. The most likely it is DMD. If your projector is new with one year warranty, send it to the company for repairs. They will replace it at no cost.
sonsunny
Top InFocus Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
