Onkyo TX-SR606 Receiver Logo
Posted on Mar 03, 2018
Lost signal while using Xbox 360...dips to black
While using the Xbox, randomly the signal will be lost and dip to black. Occasionally the input will change itself. The HDMI cable works fine directly input to the tv. Noticed an occasional signal dip from the direct tv also, though I maintain picture, just drops audio for 2 seconds.
5 Related Answers
Anonymous
  • Posted on Dec 11, 2007
SOURCE: No video throught HDMI output
press set up go option number 1 then go hdmi monitor and input yes. then press set up again
Duke83
  • Posted on Feb 04, 2008
SOURCE: HDMI sound?
i am new at this, as i just got a receiver with hdmi ports as well. but the receiver will not transmit audio through hdmi, you have to use either the optical cables, coaxial inputs, or the rca red and white inputs.
Anonymous
  • Posted on Jan 06, 2009
SOURCE: new home theater setup- no signal at tv using onkyo tx=sr605
This might somewhat help. Today I went back .. I went HDMI out of the Cable box and DVD player into 2 of the TVs HDMI ins. The digital audio out from each, straight to the receiver and things are working ok. All speakers are working OK. Sound isnt as loud or crisp but unfortunately I found no other solution.
Anonymous
  • Posted on Apr 05, 2009
SOURCE: Onkyo TX-SR606 getting no sound from HDMI sources
Not sure if this is your fix, but I had what I thought was the same problem. I played with my Onkyo quite a bit ensuring the correct assignments for HDMI, audio and all that stuff. Turns out I neglected to make sure the output devices were properly assigned. Many devices aren't default to output sound over HDMI. I changed the audio out settings on the cable box to HDMI and suddenly the Onkyo worked great. I know, I'm an idiot for not checking that in the first place, but maybe someone out there is having the same trouble as well.
Anonymous
  • Posted on Apr 19, 2009
SOURCE: Picture sound blackout (blink) when cable box/receiver HDMI used
Onkyo service told me, the second timethat I called them, that there is a known HDMI handshake issue with Motorola and Atlanta Scientific cable boxes. The only solution, and it was a solution, is to connect the box through the HDMI 1 port ONLY. All the other (2,3,4) result in blinking/dropping of signal. I did this, changed the cable/satelilte setting to HDMI 1 and all is well.
Can I have my black and /or Gold GUCCI watches re dipped they have both lost their colour?
You shoud ask a jeweler about it.
MY ADVICE: Don't let to mess with your Gucci watch someone who doesn't have the technical knowledge to do it!
I have a Mitsubishi WD-73737 and when I turn on the tv the power light flashes very fast for a minute then stays a steady green and the screen is a solid blue. There is no sound as well. I have tried the...
Do you have the input turned on that you use the xbox for? Try different inputs as well. If you are getting the menu to come up, the blue screen is telling you that you don't have a signal being run through that particular input.
It keeps on randomly disconecting from live sometimes it says lost connection to host.thn i turn it off and on nd it stll doesnt wrk!
if it wireless the get a usb exstention and relocate it, and make sure its not by anything that could hinder the signal
My xbox 360 won't read any disks at all, not games, not movies, not CD's; it just says reading then open tray
Best bet would be to clean the disc reader by either using a Ku-tip dipped in rubbing alcohol or by using a actual cleaning disk for a computer
1helpful
Had internet connection turnnt off xbox,turned back on lost connection and will not find ip address
Double check you settings and passwords for access to the internet. Make sure that the neworkname is inputted correctly and that the password is correct.
Lost color
same happend to me u might not know but i bet its something on ur tv
3helpful
Rca tv model f35673mb - lost remote.... switch to video ???/
I asume your game systems and dvd player are hooked up via the rca inputs.So all you would need to do is purchase a universal remote,program it for your tvand press ch00 which should be the video input.make sure your dvd or game system is on so you know if you are on the right channel
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
John
John
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
