Bought a used vehicle wish dash already installed. Got a new truck and swapped the in dash, now i dont know the security code cause im not the original owner. How do I reset the code?
This deck uses a unique security code that is created when activated and can't be reset or otherwise determined. If you do not know this code, Kenwood may take it in and reset it for you, but would require taking the entire deck to a service depot that repairs kenwood electronics. Read more on page 42 here: http://www.kenwood.net-disp.com/i/05products/kdc_x789/pdf/kdc_x889_x789_mp828_k_english.pdf
The Security features are installed into the ecu at the dealership. you can unplug the battery for 15 minutes and then re connect them this resets sensor codes and such but im pretty sure that your problem will still persist. i know for a fact that even if you replaced the ecu the security features will not let the vehicle run without pairing the new ecu with the existing security features.
Sometimes the alarm box is under the dash on the drivers side. Did you try using the key to lock and unlock the driver side door? Some vehicles this will deactivate the alarm.
ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000 Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile. send the IMEI no to me and i will reply you with unlocking code. IF Problem not Solved So Please New Software install in the Phone Problem will Solved
Most remote starters do not lose their "memory" when power is lost. However, if an older version bypass module was used for your vehicle it may need to be reset but you must know the model. If you are not able to look under the dash panels yourself, you should take it to your nearest dealer/installer. Some also reset or relearn after the first key start. The FCC number off of one remote may help narrow down model of the remote start also. Vehicle info will also be helpful.
DC
