I try to delete all pictures but of coarse it will not let me delete protected ones I need the space for new pictures. I think this got done by mistake.
Try to remove first the memory card of your camera. After you remove the card you can see a small button at the side of the memory card. Just slide the small button to unprotected. Insert your memory card back to your camera and try to delete pictures.
The protect function allows a user to protect a picture from accidental deletion. To unprotect a picture on your camera, scroll to the protected picture that you want to delete, then press the Menu button (the button to the right of the Play button.) Scroll down the menu and you should come to an option that allows you to Protect/Unprotect the picture. Since your picture is currently protected, deselect that option. You should then be able to delete the picture normally.
Alternatively, you could also format the memory card, however this deletes ALL photos and data you have on the memory card. If you are trying to completely clear the memory, this is the best way. After turning on your camera, simply press the Menu button, scroll to Setup, then scroll down to Format. Select Format, it will ask you if you want to format the memory card, or the camera's built-in memory. Format whichever one you want to clear, if you are using a memory card then your pictures are stored on the memory card. It will take a few seconds to format.
You haven't said which exact model you have, but if you go into the menu of your whilst in playback mode you'll find an option to protect or unprotect each image.
If this is no help to you then please state the exact Fuji model and confirm that you're using an xD card and I'll research a model specific answer for you.
Do you have any of the pictures stored as contact pictures? Sometimes this will block you from deleting them, if you have a memory card try just moving them to the memory card and then deleting them from there. Sometimes an alternate file browser will override the access denied. I apologize for not having one off hand, try www.download.com find your device or at least a windows mobile program. Goodluck!
Each time you execute finalization, the disc remaining space will decrease by approximately 13 MB. If you don’t have enough room, it won’t allow you to finalize the disc.
To finalize this disc, you have to delete some pictures to make enough space. But don’t worry, before you delete those pictures, you can save them to your computer.
Find out the CDs came with your camera, refer your manual page 51 - 61 to install ‘PIXELA PTP Manager’ , connect your camera and computer with USB cable, and copy some pictures to your computer, then delete the pictures on camera side. If still not enough room, copy more and delete more. make it enough to do the finalization.
Hello there. the motorola w375 has a protective code that keeps users from deleting pre-loaded items. so in general what i am trying to say is that what you are trying to do is impossible. now this is one of the downfalls about this phone. insufficient space. unfortunately the space provided is the only one you will get. hope ive helped bye!
You need to delete files from your memory. Pictures take up a lot of space, to be able to take additional pictures you should probably delete some of the ones you have saved in the gallery currently.
Delete files to make more space and you can take more pictures.
- Turn on camera - Press on PLAY BACK button (wherein you are viewing pictures) - Press MENU button once - Scroll to the right until you PROTECT menu tab - Scroll down to SELECT or ALL PICS - Highlight ALL PICS - Press MENU button * It will be displaying pictures and another submenu telling you to UNLOCK or LOCK pictures - Use your zoom switch to change the submenu to UNLOCK - Once you've seen UNLOCK - Press MENU button so pictures will be released/unlocked
Those are the steps on how to UNPROTECT pictures on your A503.
If you'll be having questions, feel free to post it here.
