T.V STANDBY LIGHT IS FLASHING BUT CANT VIEW ANYTHING AND IF WE TRY TO SWITCH ON /OFF AGAIN THE STANDBY LIGHT FLASH.WHAT CAN I DO?
The standby light blinks 5 times
Flash 9 times then pauses but won't turn on
Can you determine if its flashing a certain number of flashes before a slight pause. If so let me know the number of flashes as this would be an error code. If its just continually flashes then you have a power supply problem that will need to be diagnosed.
Resetting the main unit
Use this procedure to reset all the receiver's settings to the factory default. Use the front
panel controls to do this.
1 Switch the receiver into standby.
2 While holding down the TONE button, press and hold the STANDBY/ON button for about three seconds.
3 When you see RESET? appear in the display, press ENTER .
OK? shows in the display.
4 Press SYSTEM SETUP to confirm.
OK appears in the display to indicate that the receiver has been reset to the factory default
settings.
hey i have the same problem everytime i turn it on the stand by flashes 5 times.......plz help
Standby light flashes when attemoting power on.
Sont kp-46wt520 blinks 9 time. Who could we fix this, have parts and not sure where it goes.
my tv does not turn on any more, the standy by light lust keeps flashing. what can i do
stand by light flashing tv wont turn on
tv wont turn on standby light flashing
can not find ic708 or ps701 or ps702 on this model kp-46wt520 model scc-m37b-a
flashing wont turn on
The light that says stand by flashes 9 times and then it makes a pause and after that it does it 9 times again and so on, please let me know what i can do....
my 2000 sony tv kp-61........flashes 4 times
lite flash 9 times what do i need to do
my kp46wt520 turns on with sound only for 10 seconds then clicks off followed by 5 blinks. what does this mean?
standby light flashes but won't turn on
I have the same flashing problem on my kp-46wt520. (9 blinks). Any suggestions?
same problem but 6 blinks ... what does this mean ???
I have a red flashing light sequence 4 flashes.
