Hi
may u help me.
i can install my DSL 200 modem in windows vista 64
i want thats drier
plz help me.
Helppppppppppppppp
driver vista 64 for adsl modem 200
Hi
if win vista driver does not work and does not install .
i give u an solution that 100% work
at first go to the Device Maneger
then go to the modem option
select dirver update and let windows get update from internet
after that run vista program and when it whant to replace driver dont let it and jost install software
then you will see that it works good
سلام به همه عزیزان برای حل این مشکل فقط کافی هست که اجازه بدین خود ویندوز درایور این مودم رو از اینترنت دریافت کنه بعد نرم افزاری رو که از لینک های بالا گرفاتین نصب کنین و وقتی که میخاد درایور رو نصب کنه بهش اجازه ندین که درایور جدید رو جا گذاری کنه در این صورت برنامه نصب میشه و شما به راحتی از مودم خودتون استفاده میکنین.
خوب بود؟؟؟؟؟؟
Try going to www.dlink.com.au. Search for the DSL 200 at the products drop down menu. Click DSL 200. Click tech support then click download then download the driver for the Vista. Please note that the version of the modem that can only work with vista is generation C or Revision C.
There is no Vista Driver for this modem. They want you to buy a new one, and that's the only workable solution. Unless you wanna format your PC and install Windows XP. In this case you need to install XP version 1, then install the driver for the modem, ONLY THEN you can install Service Pack 2 and 3, otherwise your modem will still not work.
I have tested all of the solutions above nut nothing changed, on vista when ever i want to install it's driver it said that you have to reboot your computer and this loop will never last!
pleaaase help
Use the Following URL for downloading Vista driver for DSL-200:
ftp://files.dlink.com.au/Products/DSL-200/REV_C/Drivers/DSL-200_Rev.C_Win_Vista_driver/
The Source FTP Address:
Hi may u help me. i can install my DSL 200 modem in windows vista 64 i want thats drier plz help me.
u can use this driverhttp://www.megaupload.com/?d=GP56IU18
Cxvxcv
Http://www.dlink.co.uk/cs/Satellite?c=Page&childpagename=DLinkEurope-GB%2FDLGeneric&cid=1197344154822&p=1197344154822&pagename=DLinkEurope-GB%2FDLWrapper
dgvefv
i need help too.
zv,.mv
I have the same problem ...pls help me...
من هم همین مشکلو دارم یکی کمک کنه
chi kar konam
