Question about La Crosse XG-55 Wrist Watch
Changed battery now it won't come on - La Crosse XG-55 Wrist Watch
    President:
  • 2,501 Answers
Try shorting the battery case to the watch chassis (using a pair of tweezers perhaps).
This seems to be a standard instruction and I think this resets the watch.
Posted on Apr 24, 2010
SOURCE:
How to change a battery
If watch expensive, take it to Shop to get it changed , if watch waterproof, it needs to be changed at a shop, as when battery changed , shop checks that the watch is still 100% waterproof.
Mar 07, 2015 | Tw Steel Grandeur Diver chronograph Quartz...
Watch won't work after changing battery
Shortcut battery with AC contact. AC can be found on the sides of watch movement(very tiny). You have to use pointed tweezers: one end on battery+, another on AC contact for three secs..
Apr 20, 2013 | Watches
Won't run, it it battery operated?
yes it is battery operated,sudjest you get the battery changed at local jewelers.
Jan 09, 2013 | Fossil JR9413 Watch for Men
Just change the battery on my Nike Anvil WC0020 watch and the alarm won't sound for the timer as well as the two alarm settings.
If you changed battery yourself, you've lost the tiny spring without noticing it. Carefully check around the place where you changed the battery. The spring itself is very, very tiny, so, be as concentrated as much as you can. That spring (coilspring named by watchmakers) transmits the signal from watch movement to the watch back cover where the sound membrane is located. In case if you find it, open the watch and insert that spring with the bent out end first in to the desired hole in watch movement (should be named COIL SPRING). After that re-assemble watch and the sound should work.
Jun 02, 2011 | Nike Mettle Anvil Super Watch Obsidian...
My Casio watch Battery was just changed now I can
mcdevito75 here, Return to where the battery was changed, for adjustments.
Jul 12, 2010 | Casio Watches
I have a GUESS watch style 86013L and the battery was changed 3 days ago and it's already dead. What size battery does this watch take?
Bring the watch back to the place where the battery was changed, after only 3 days they should at least try another battery , maybe this battery has just gotton loose.
Jun 15, 2010 | Guess G66355L Wrist Watch
I changed the battery in my Fossil ladies watch and it still will not keep time. The hands are going around but it is not keeeping up with the time
mcdevito75 here, Just had the battery changed, if the watch was running fine before the last battery died, and now with this battery change the watch can"t keep time, try another battery as any Battery can be weak just from storage.
Jun 14, 2010 | Fossil JR8096 Wrist Watch
Screen stuck on battery life indicator
My guess is the battery was just changed? This watch needs to be cleared when the battery is changed. I recommend seeing a watch maker/technician to have the circuit board AC'd.
Sep 20, 2009 | Garmin Forerunner 405 Fitness Watch/GPS...
La Crosse XG-55 Wrist Watch Logo
349 people viewed this question
Top La Crosse Watches Experts
Arturs Kalnins
Arturs Kalnins
Thomas Perkins
Thomas Perkins
Are you a La Crosse Watch Expert? Answer questions, earn points and help others
