GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
Posted on Apr 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My GE Profile Performer refrigerator is freezing fruits and veget
The normal temperature setting is 5. but I set at 3, and the fruits and vegetables in the bottome of the refrigerator is still freezing.
Anonymous
Level 2:
Scholar:
  • Expert 126 Answers
  • Posted on Apr 24, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
126
Questions
0
Helped
34833
Points
385
PUT THE REF. ON 5 AND SET THE
FREEZER ON 2 1/2 AND SEE IF THIS WORKS
GE psc23ng...the veggie bin is freezing vegetables and temp. on fridge and freezer does stay put!!
GE Appliances Customer Phone Number Shortest Wait Best Support
GE Appliances Calls You Instead
Good Luck
THE FIX
Avoiding Frozen Lettuce
By TIM McKEOUGHPublished: March 18, 2009
Q. How can I keep produce from freezing in my refrigerator?
More Articles in This Series
Jason West, the marketing manager for refrigeration at General Electric. "Nobody really knows what the temperature of B is, or what the temperature of No. 5 is."One solution is a refrigerator thermometer. Oxo makes a handsome one with a round dial attached to a suction cup that can be installed easily on either interior side wall ($12.99 atoxo.com). Taylor makes a rectangular digital one that is installed the same way ($12.47 atamazon.com).
Once you have the thermometer, "put it in overnight and check it immediately in the morning, the first time you open the fridge," Ms. Reek said, because the temperature varies during the day as the door opens and closes.
The problem might be where you're storing fruits and vegetables, which are sensitive to cold air. Leafy vegetables are especially prone to freezing, Ms. Reek said, because of their high water content.
Although some newer refrigerators have separate cooling mechanisms for the main body and the freezer, most refrigerators cool by funneling air from the freezer into an opening near the top rear of the main compartment.
Fruits and vegetables should be kept away from this outlet, Ms. Reek said, or else "you're going to be blowing that very cold air right on the produce."
Both she and Mr. West recommended keeping produce in the crisper drawer, away from the circulating air.
"You don't want the moisture to transpire out of the product and make it limp," which can happen with produce on a shelf, Ms. Reek said.
If the crisper is full and some produce has to sit on a shelf, it's better to keep it at the front of the refrigerator, because cold air falls down along the back wall. Along with the area directly beneath the outlet, Mr. West said, "the back and bottom of the refrigerator tend to be the coldest spots."
Shirley O. Corriher, a biochemist and cookbook writer, suggests shaking off all the surface moisture from produce and sealing it in heavy zip-top freezer bags before putting it in the crisper drawer or on a shelf.
"Oxygen is a major villain, so to speak, in the deterioration of fruits and vegetables," said Mrs. Corriher, the author of "BakeWise: The Hows and Whys of Successful Baking" (Scribner, 2008) and "CookWise: The Secrets of Cooking Revealed" (William Morrow Cookbooks, 1997).
Lettuce leaves, in particular, benefit from being sealed in plastic, she said, and you should roll the bag "until you squeeze all the air out. That lettuce will keep for three weeks. It's just amazing."
Still, Ms. Reek said, "the objective of food is to eat it."
"If it's fresher, it's going to have higher vitamin content and be healthier for you," she said. "So it's really better not to plan to store food for ever and ever."
Temperature in the FF side dropped to low
Hi Steven,
Sensor / thermostat problem.need to replace.
regards,
nuwan.
PSC23NSTESS FREEZING VEGTABLES
Side by Side ModelsIf foods, such as fruits and vegetables, in the refrigerator are freezing, it can be caused by several things. First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenheit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • If food in the bottom of the refrigerator is freezing, this could be caused by a refrigerator not having enough food to absorb the cold air.
  • If food in the door is freezing, move the door bins up or down so they are one notch away from freezer vents (Side by Side models only).
  • The fresh food control should be at the normal setting of 5.
Freezer on Top Models
First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenehit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • Since the cold air coming into the fresh food section originates in the freezer above, the rear of the top shelf will be the coldest spot in the fresh food area. Avoid placing delicate items that freeze easily on the back half of this shelf.
  • If food is freezing in the produce (fruits and vegetables) or meat pan, it may be that the temperature controls are not set high enough. Since cold air naturally falls, the pans can get too cold if the refrigerator is not running long enough to maintain good air circulation. Adjust both controls up one notch.
1helpful
I have a GE side by side refrigurator model Gss201epc ww serial Tf220054 and am having a problem with stuff freezing in the crisper, I do not see any type of adjustment any ideas here? Thanks
initially, set the refrigerator compartment control at 5 and the freezer control at 5 and allow 12 hours for the temperature to stabilize.
Several adjustments may be required. Adjust the controls one increment at a time, and allow 12 hours after each adjustment for the refrigerator to reach the temperature you set.
Adjustable Humidity Crispers and Snack Pan (on some models)
HIGH LOW
HIGH LOW
Normal
Coldest
Slide the control all the way to the High setting to provide high humidity recommended for most vegetables.
Convertible Meat Pan (on some models)
The convertible meat pan has its own cold air duct to allow a stream of cold air from the freezer compartment to flow around the pan.
The variable temperature control regulates the air flow from the freezer compartment.
Slide the control all the way to the Low setting to provide lower humidity levels recommended for most fruits.
I have french door with freezer on the bottom refrigerator in the GE profile line. I have the internal ice cube maker. My ice cubes melt into one big block of ice. I lowered the thermostat to -5 but that...
check ur temperaTure in the freezer make sure it is 5 degrees fahrenheit or lower if it is u might need to see if ur ice maker tray has a crack i it to where when the water goes in to be frozen it runs out a crack and if all this is good check to see when the ice maker fills up its just not running over
I have a GE profile side by side and the fruit vegetable drawers freeze what ever is in the them. The temparature in the refrigerator is 37 degrees F
If you cannot adjust the temperatures or close the air dampers on left side of the crisper contact me withe the model number. 38 degrees is perfect safe temperature for lower section. There are several styles of the Profile. That is why I asked for model number is to see exactly which style you have. For example PSS26MRSS would be what to look for. Sea Breeze
Food (vegetables, fruits) on the refrigerater side freezing
Your model has a control damper inside the vent. The damper opens and closes with changes in temperature. It has a pig tail spiral thermostat on the side and if it goes bad the door sticks open or closed. Sometimes it is just frost but you will need to get to it. I will send photos and links in a moment, Thanks Sea Breeze
2answers
GE Profile Arctica Side-by-Side Refrig PSC23MGMB IS WAY TOO COLD!
it sounds as if the ice door is not closing properly. Check the little rubber door seal to see if it is sealing properly. If not try a hair dryer to soften it. Otherwise you have to buy a door kit.
2answers
Everything freezing in vegetable and Custom Cool compartment
you have a temp setting above those shelves left side has a porkshop and left side has a carrot i belive set to to the left side to vegies and see if it helps if still all freezes the you have a broken damper on top that letts air in when it does not needed
Top Refrigerators Experts
vince
Johnny 1000
