Been working for days trying to fix this wireless laptop won' connect to internet explorer. Wireless router says I'm connected with good signal strenghth. this just started a few weeks ago. worked great before then.
have restored to factory nothing works.
If Nothing else changed in the last 2 weeks, such as a new router, or other hardware changes, AND it just started happening, I suggest you do a "system restore" to a date BEFORE the problem started.
This should correct the problem, and if you did any updates or other software installations, you will need to re install them.
Finally, one option prior to system restoring is to turn off the wireless router (unplug it) and then wait a minute. Plug back in. Then turn on your computer. You can try this first if you haven't already..
Good luck..
If you are unfamiliar with Vista's restore feature, check this link out, and you should be able to get through ok.
Note, again, remember to restore to a date before having the problem. http://www.howtogeek.com/howto/windows-v...
Let me/us know if this solved the problem?
