Danby DDR583R Dehumidifier Logo
Posted on Apr 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
LED display weak and hard to read. runs constantly
LED display weak and hard to read. Unit has run constantly since I bought it in Sept of 2007. Can I get a replacement LED display and is it something I could do with basic tools?
Thanks,
Leon
Marlette, Michigan
Peter Hampton
Level 2:
Habit-Forming:
  • Expert 193 Answers
  • Posted on Apr 24, 2010
Peter Hampton
Expert
Level 2:
Habit-Forming:
Answers
193
Questions
0
Helped
79385
Points
348
Leds don;t dim as they get old they are either on or off and leds have a life span of around 20 years if driven with the wright voltage.it will a the plastic cover that covers the display or b the voltage to the leds in not wright.
Fan always runs, speed doesnt change (low/high), setting humidity level doesnt impact...is this a control board or circuit board issue?
Verify the humidity reading with another device. Perhaps the humidity sensor is dirty or bad.
Another possibility is the switching device that runs the compressor and fan is shorted. If it's a mechanical relay, the contacts may have welded together, or if it's a solid-state relay, it's got a punch-through or meltdown in a device junction. My guess is it's a mechanical relay since you mention it used to click on and off and now you don't hear that. The relay may be on the control board, or it may be mounted separately - I don't have a photo or diagram of the inside of your model available.
We don't have a manual, it's a new unit but never been used. We can't figure out what all the control panel buttons mean. Help please.
if its a newly mfg unit then yes the fans gonna run all the time , that's done to increase efficiency , if you hold down on arrows then you should be able to adjust the rooms humidity level, the default screen is the actual rooms humidity level , if you hold down mode button , this will cycle thru some timer modes that ind on the display
it should turn itself off when bucket is full , this even stops that fan from running most times
My Kenmore dehumidifier is set for 65 the display constantly reads 90 and is always running and collecting water the unit never turns off and the display number always stays at 90. What is wrong?
wow it seems you really have a lot of moisture , 1st i suggest you find and seal location of water entry second you might have to consider getting a second unit or a larger unit to work as your primary and save smaller unit for use as a back up
they are rated in Pints per hour the bigger the number the more water they pull out of air sounds as if your gonna need a 60 PPH unit or larger
Btw : 70%rh is considered the "normal" of the avg home
yours at 90 % rh is unhealthy for humans and will promote respatory mold growth and all its complications unit setting of 65% is telling me that unit is too small to handle amount of water you have
Dehumidifier runs continuously and displays higher than normal humidity levels.
Probably some glitch with the sensors. I recommend taking it to a service center.
Just bought a brand new Frigidaire 50 pint dehumidifier. As waited 2 hours before plugging it up and when I did I got a ES error, the unit runs but the display flashes between "CO" and...
Read the instruction manual thoroughly and ensure you did everything exactly. If it still doesn't work it is faulty and should be returned.
DeLonghi DEN500P Dehumidifier Humidistat
I have the delonghi DEN500P and the unit runs but does not condense any moisture? The appropriate buttons have been set to bring the unit humidity setting well below humidity in room
Just bought a new dehumidifier. does the fan
it should shut off when the compressor is not running. only portable a/c can have fan running constantly
2answers
Humidifier stopeed working
You have a bad fan motor. Put your hand against the grill to see if there any air movement. You need to buy a new fan motor assembly, it is attached by two long
bolts, easy to swap, except the wiring may not be easy. May have to cut the 3 wires and resolder. Get to the motor by removing the back panel and then the fan. Removing the fan may not be easy, they put some gunk on the spidle thread.
The cheapest price I have seen for the motor is $27-$28, shipping about $8 and tax
about $1.5.
Top Danby Dehumidifiers Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
ADMIN Andrew
ADMIN Andrew
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
