1 scoop for every 2 cups. Then work from there.Good luck. Ron
SOURCE: Senseo coffee maker
There isn't a way to adjust it. The senseo is calibrated to make either a 4oz or 8oz cup. Unfortunately, we are so used to buying mugs at the store that are MUCH bigger than this!
SOURCE: The coffee maker won't brew
same problem I have...took off bottom; two front 'screws' I had to drill out. Looked inside and threw it out!!!!!!! Not a Quality Item Clark.
SOURCE: Flavia Coffee Maker coffee sprays outside cup
I bet that's wild thing to see. Ok, Is ther a basket that'ds supposed to be there? If not,heat up a large paper clip,straightened of course and run it yhrough the hole. If the nozzle will come off, clean the burrs of the edges of the hole on the inside. It sounds like it's restricted if it's spraying. Good luck
SOURCE: Our coffee maker is only filling 1/2 a cup and
I have gone through two units -- the problem is with the water tank seal to the unit. Here is how to come up with a workaround: http://www.nate-lewis.com/blog/?p=288
SOURCE: Need instructions for use of Farberware 55 cup Coffee Urn
Hi 2 scoops of coffee to 3 cups not mugs. Then take it from there, adjust to your liking. Ron
