Keurig Platinum B70 Coffee Maker Logo
Posted on Apr 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Keurig Platinum B70 is leaking. When I put the water reservoir on to the coffee maker, water seeps out the bottom where the reservoir sits into...almost like the little valve in the reservoir stays "open" and continues to drain water into the coffee maker. It creates a puddle around the bottom of the pot and all over the counter. Any ideas to fix it would be appreciated.
  • Anonymous Feb 10, 2012
    I have the same problem but it's not the reservoir thats leaking its when the reservoir is in the machine it leaks not when it's out so frustrating please help
  • Anonymous Mar 12, 2013
    I too have the same problem with my Keurig, leaks when I put the reservoir onto the coffee maker.
Anonymous
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Aug 23, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
8186
Points
6
My Keurig B60 had the same issue. The water reservoir has a valve in a nipple on the bottom that slides into a clear plastic fitting within the base of the unit. Water from the reservoir is supposed to pass through the fitting and into the pump, which is also in the base. Over time, hard water deposits can build up on the nipple or the mating fitting (or both) such that a good seal is not made when the reservoir is in place and water slowly leaks out the bottom. To fix this, I removed the five screws on the bottom of the Keurig and then removed the two screws which hold the fitting in place. I gently cleaned both the clear plastic fitting and the nipple in the bottom of the reservoir with white vinegar. After rinsing both with clean water and drying both, I applied a small amount of silicon faucet grease (available at any hardware store) to both parts. I haven't had any more leaks since, although I assume I will have to repeat this operation periodically.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 01, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
5828
Points
Thanks for all of the advice. Although my unit was brand new and leaked from the underside from start up, i know mine had a different issue that calcium build up. Although by removing the two screws right where the intake valve is led me to see a tube zip tie broke a small tube had been disconnected. If i hadn't read your post, I would have never known or it would have taken me forever to find the cause of the leak. I have the B60 WR system...many thanks!!!
Clayton McCune
Level 2:
Champion:
  • Expert 214 Answers
  • Posted on Jun 14, 2010
Clayton McCune
Expert
Level 2:
Champion:
Answers
214
Questions
0
Helped
150384
Points
299
Could need new seals. To check; fill tank with water and hold it in the air to see if you can see water leaking. If it leaks replace seals... You can find them here:
http://iwantsweetdeals.com/Keurig-Replacement-Water-reservoir-Seals--P1286283.aspx
Keurig troubleshooting
Water pot part leaking from the rubber part on bottom? that's the only thing I could think for you to check. Maybe not getting a good enough connection to the coffee maker itself
My Keurig leaks from the bottom, it's a pain.
You may have water in the holder that supports the CUP. It needs to flushed as it has a limited area for maintain the overflow.
Keurig B70 automatically pumps water when turned on
Purge and Descale unit to reset the system to original state.
Today,my keurig started to short cup me, and shortly after that, it will not brew anymore! I noiced while de scaling today( recommended per keurig), that more water is pouring into the water resivor, vs...
The water pump is probably starving for water:1. Remove the clear plastic reservoir and set it aside. 2. Look into the hole that the reservoir sits on. You will see a fine plastic screen that keeps debris from getting to the pump. 3. Clean off the screen. You may have to disassemble the bottom of the machine and remove it to do it right. 4. Put everything back together and the short-cup problem will be history.
Top Keurig Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sean Wright
Sean Wright
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
