T-Mobile Sidekick ID Cellular Phone Logo
Posted on Mar 23, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sidekick wont turn on
My sidekick id wont turn on. it'z in good condition but it wont turn on. what would be the problem and is it worth getting fixed?
  • 1 more comment
  • Anonymous Jul 23, 2008
    i have had my sidekick id since december 4, 2007 and it has been workin perfectly fine ever since i got it. i didnt get it wet or anything but one day last week it just shut off and i charged it but it wont turn on! what do i do?
  • boomerbabe Aug 30, 2008
    i Have A Side Kick 3
    Its In Good Condition
    When I Charge It The Light Is Red
    But It Wont Turn On
  • Anonymous Sep 15, 2008
    my sidekick id wont turn on nomore one day it froze up and i took the battery out it and then i put it back in and the round button turns green every time i put the battery back in but my phone wont turn on
A
Anonymous
Get new battery. happened to me
A
Anonymous
Buy a new kind of sidekick thats not the id or 3! but try the charging cradle it worked for my friend but not for me!
Anonymous
Level 3:
President:
  • Master 625 Answers
  • Posted on Mar 30, 2008
Anonymous
Master
Level 3:
President:
Answers
625
Questions
0
Helped
344594
Points
1259
If you can, try a friends battery, either from a sidekick ID or sidekick 3. The Sidekick ID seems to be having the same issue as the sidekick 3 whefre the charging port goes bad. The best worka round for that is to get a charginfg cradel that has a spare battery slot.
http://repairmysidekick.org/SideKick-Repair-Parts/Sidekick-3-Spare-Battery-Charger
Sidekick id charger light comes on but phone wont the screen wont turn on but charger light is on
Sounds like you unit is not charging. The Sidekick ID's are notorious forthat. If you have a friend that has a sidekick ID or Sidekick 3, see ifyou can try their battery to make sure you phone is working ok.
If so, your best option is to get an external charger that has a sparebattery slot That way you can charge the battery outside the phone!They run about 25-30 dollars on ebay. an extra battery is a good idea so you can have one charger at all times.
Sidekick ID and Sidekick 3 External Battery Charger
Sidekick lx wont turn on
sir please check for the battrey
Sidekick id
-take a battery out for 2 mins then put it back in. -switched it on and see if the screen is visible. (dont be freak out if everything gone, it will come back in fews so give it some times to have them back up again *contacts, notes, etc etc*)
if nothing worked, then youre more than likely looking at get a new screen for sidekick id.
you can find some around on ebay for cheaper or broken id with a good screen in a good condition.
good luck and let me know if need any more assistance, im more than be glad to help some more if i can.
2answers
Side Kick Id
A replacement LCD Screen for the Sidekick ID runs from 45-60 dollars. That is on ebay which is the only place I have seen them for sale.
Here is a link for them:
Sidekick ID LCD Screens
Hope that helps out.
SIDEKICK ID IS BROKEN
well the problem is the sidekick not the battery i suggest using ur battery in a friends id or 2 or 3 and see if it works if it does well that sidekick id is no good
1helpful
Phone wont charge
Stevey-
The sidekick ID charging port can go bad like the sidekick 3's. An easy workaround is to get an external cradle that has a spare battery charging slot.
The trick is that the sidekick 3 and sidekick ID batteries are the same so the sidekick ID battery can be charged by the external cradle. An extra battery is a good idea as well so you can have ine charging at all times.
Check the cradles out here.
Sidekick ID external Battery Charger
My sidekick wont turn on
corbolicous1-
Is it a sidekick ID? If you bought if from t-mobile and it hasn't got wet or been dropped then call T-mobile CC. IT should still be under warranty. Do you have a friend that has a sidekick 3 or a sidekick ID that you can try the battery from(they are the same) What type of charging cradle, one witht the spare battery charging slot? Let me know....
Wont turn on
I don't know whats wrong with your sidekick ID but if you want.... i'll buy it from you. hehe
you interested in selling it?
2answers
Phone will not turn on
Sounds like your charger port is busted. Ti is a common problem on sidekick 3 and can effect sidekick IDs as well. A fairly cheap workaround is to get an external battery charger. It will have a slot to charge the sidekick battery external formthe phone. They sell on ebay fior about 25 dollars.
The sidekick ID and sidkeick 3 batteries are the same so it will work. Check then out here
Sidekick ID battery charger
Trouble with sidekick id b
make sure the battery is properly inserted/.
Top T-Mobile Cell Phones Experts
Rob Hill
Rob Hill
Thomas Perkins
Thomas Perkins
ADMIN Andrew
ADMIN Andrew
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
