Briggs & Stratton 66set  Panzer Tractor Decal 6hp 1960s Logo
Posted on Apr 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Engine wont start
What is the gap on the intake and exhaust valves on a briggs and stratton 14 hp vanguard engine model 28P777
Anonymous
Level 1:
New Friend:
  • Contributor 23 Answers
  • Posted on Apr 23, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
23
Questions
0
Helped
9746
Points
43
Go to youtube and type in valve adjustment on briggs,very simple procedure to do.
Anonymous
Level 2:
  • Expert 252 Answers
  • Posted on Jun 01, 2011
Anonymous
Expert
Level 2:
Answers
252
Questions
Helped
173681
Points
510
Hi there
inlet gap 0.003" ex gap 0.005"
set them when engine piston has moved past tdc on compression stroke
by 1/4 inch , this eliminates decompressor from lash adjustment
cheers pauly46
My briggs and stratton 18 hp vanguard model 356447 will not start just back fires through the carb. I have good comprssion and spark at both plugs. I replaced the flywheel key as thought the backfireing...
check intake valves for proper seating. If the valves do not close completely it will allow the engine to backfire thru the carb. Another possibility is internal timing caused by the misalignment of the timing gears between the crankshaft and cam gears.
Briggs and Stratton 23 hp lawnmower engine exhaust valve keeps sticking
it is possible that the valve stem is bent or has a build up on the stem that is jamming in the guide. Pull the head and replace the valve.
2answers
What is the valve settings on a Model 31 C707 Type 0175E1 Code 040804ZD Briggs Stratton Engine ?
Hi and welcome to FixYa, I am Kelly.
Your engine service manual is here:
http://www.mymowerparts.com/pdf/Briggs_&_Stratton_Service_and_Repair_Manuals_Spec_Charts/276781%20Single%20Cylinder%20OHV%20BRIGGS%20&%20STRATTON.pdf
Spec sheet on page 175 of the pdf file above.
The valve gap is 0.003 - 0.005 for intake
exhaust gap 0.005 - 0.007
Valve maintenance is in sections 6 and 12 with some comments in section 1.
Thanks for choosing FixYa,
Kelly
18 hp vanguard 165lbs and 180 lbs compression have to hand turn engine past compression or starter wont turn engine over
if its hard to get the engine to turn past the compression release then pull your valve coversand try setting your valve lash
.006 on intake
.008 on exhaust
What is the valve clearance on 23 horse brigs &straton intake & exhaust
The solenoid on carb was bad causing reduced gas to motor and low power
4helpful
I have a 23 hp Briggs vanguard engine-V Twin Model 380447/type 76-E1 code 4241. The engine is less than two mowing seasons. The engine will not turn over properly and I have used another start I have and...
It will probally be your valve setting might be off so pull the valve covers off and try setting your valve lash
Heres the factory settings
.006 on Intake
.008 on Exhaust
3helpful
How to change electric starter on vanguard 14 hp v twin vertical shaft.
Please, help me to regulate valves on Vanguard B&S 14HP OHV model:294446 tip:1141-a1. I don't know how. Thenks. My adress [email protected]
Top Briggs & Stratton Garden Experts
Jay Finke
Jay Finke
john h
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
