Technics SL-1210 Turntable Logo
Posted on Apr 23, 2010
Pitch wobble 1210
Hey i have had problems with pitch accuracy on a technics1210 mk2 for months and recently have replaced the pitch controller with a second hand pitch controller (the old one was proper knackered anyway), i have been assured that it was checked for integrity. the problem has become less acute since the swap but is still not 100% fixed. the problem is this, when moving the pitch slider through its range in certain places the speed of the platter revolution fluctuates causing sound to fluctuate simultaneously. i know your first answer will be to try a brand new pitch controller, and i will eventually, but for know i need to know what else i can do to try and improve/fix this fault. also the led on the new pitch controller doesn't work and this was also the case with the old pitch, could this be linked in some way to my current problem im wondering if my overall problem could be caused by faulty circuitry....
any info will be greatly appreciated
many thanks
dean
Anonymous
Level 1:
New Friend:
  • Contributor 32 Answers
  • Posted on Jun 10, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
32
Questions
0
Helped
10490
Points
54
I had my decks fixed by these guys they are in london.
thier websites is www.technics1210repair.co.uk
they do technics turntable servicing
check them out.
im only spreading the word due it i had my decks fixed their and i am so pleased im telling everyone so they can get the same service i did, rather than paying over the odds at some **** toster repair shop.
alan
1helpful
Technics 1210 MK2 - unstable/uneven speed problem
Since this is a direct-drive turntable, it isn't a slipping or stretched belt. You will need a technician with a couple pieces of equipment and some experience/training to find the source of the problem. I suspect the part(s) will be the minor cost of the repair.
2answers
1210 mk2 speeds up on its own
hi ,,,the pitch control is good dont chance it ..you have a problem on the main board ...of your turntable...check the cold solder of your main board of your deck....maybe some of them are loose that why you got a wiggle platter.. u...then fidbk me wat happend? u
1210 mk 2 pitch
Doubt it, ive heard of this problem before, usually people buying them second hand and the answer has always been get them repaired professionally, i dont know the reason for them doing it sorry.
1210 mk 2 strangeness
Check that your voltage settings are set correctly. This is located underneath your turntable platter. If you remove the slipmat, you will see 2 holes on the metal platter. Rotate the platter till you see the voltage switch, located @ the 9'o'clock position. Make sure it's set to your correct settings (N.America = 115V / Euro = 220V). If not, you will need a flat head screw driver to switch it. Before you switch it, make sure your unit is off and unplugged. After you swich it, it should be ok.
If your still having issues with the speed and the pop-up light, then there is something seriously wrong, and will need to be checked by a technician. Sometimes a resistor or IC will go bad, causing the speed issue, but for the pop-up light - that's usually faulty wiring generally caused by an incorrect replacement.
Did you buy this new or used? Have you had this serviced recently?
- TWEAK AV LAB
The ORIGINAL TURNTABLE Technicians
Technics 1210 mk2 problem with pitch and lights
- TWEAK AV LAB
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
