If you want a 2 ohm total load..wire it from the amp positive(red) to the first coil positive(red) and then to second positive(red). Amp negative(black) to first coil negative(black) and then to second negative(black). This will give you a 2 ohm total load on the amp.
That sub has dual 4-ohm voice coils. It can be wired either as 2-ohm, 4-ohm, or as 8-ohm.
2-ohm = voice coils in parallel (both positives and both negatives connected to your speaker amp out wires).
4-ohm = use only 1 voice coil (either is OK).
8-ohm = voice coils in series (connect the positive of one voice coil to the negative of the other and connect the remaining positive and negative to your speaker amp out wires).
