I'm not sure what you mean by "cannot duplicate problem", but will answer best as I can. If the fan is loud, and it is your CPU or case fans revving higher, it may be your CPU is overheating and the unit shuts down to prevent damage to it. If the unit will not start at all and you
get no keyboard recognition beep on boot, that means the signal is not getting from the power supply to the BIOS, directing the hard drive to start loading Windows. If that is the case, you have a severe problem with the motherboard or CPU. This kind of problem can't be handled in a forum like this. I suggest you use a computer help forum (free) which is set up for this kind of thing. The one I hang out at is
www.suggest-a-fix.com
If the noise you hear is your DVD drive, then there could be something wrong with the DVD drive which is preventing startup, I have had that a few times in my with friends' computers. Try pulling the power cable off the DVD drive and try to boot. If suddenly you boot normally you found your problem.
If your computer has never been cleaned it may be choked with dust; take it out on the back porch and remove the side panel. Reverse-flow the air direction (blow out) from a vacuum cleaner and CAREFULLY blow the dust out of the unit. I suggest using a crevice tool to better direct the airflow. Especially get the dust from the CPU heatsink and fan. You will be surprised at the cloud of dust that comes out.
Other than than, without more detailed information, I cannot be more helpful. Wish you the best!
