It does not always happen but maybe 60% of the time, my logitech cordless mouse drags and stalls and though it has gum on it's feet or has a memory problem. I replaced the batteries and it was back to it's old tricks within a few weeks. I love this little guy and hate to go back to my old, ugly large mouse.
SOURCE: Logitech cordless desktop ex110
They should have an on/off switch on the underside that you can use to switch on/off...
SOURCE: left click of my logitech cordless optical mouse not works properly
try to set on your MOUSE, here:
start-control-panel-mouse folder
hope this can help. :)
SOURCE: How do you open Logitech laser cordless mouse to replace batteries?
puhs open the logo area (palm area), toward the backend. it takes 2 aaa battery.
SOURCE: logitech cordless keyboard erratic after cleaning keys
seems to be that you may have accidentally swept some dirt underneath the keys.
try pressing each key individually in word and narrow down the affected key or keys, then remove the affected keys (using a keyboard key removal tool, or very carefully by hand) and clean underneath the key with a small dry clean brush both under the key and the board section it lay in, then replace the key and type the key again, if that has no luck then try the process again.
hope this helps
kev
SOURCE: Changing the batteries on a cordless Logitech mouse
hello ,on the bottom of your mouse there is a cover that you remove thats were the 2 aa batteries go. the cover has the wireless info on it you'll see a spot were you can use your finger nail to pop the cover off then after installing your batteries just pop it back on.
