turn the speed up some, unplug Charger, put brake lever in drive mode - hard to push, restart with the key. make sure no damage has happened to the wiring harness that connects to the back. Circuit break may need to be pushed in. this is a start. Next thing would be the Throttle and speed pot.
There are a few things to consider with this type of problem.
How old are the batteries. When did you last have them tested. Is the charger output ok on load (test with an amp clamp type meter). is the charger the correct one for these batteries, small output chargers take longer to charge big batteries. Are all connection tight on batteries and anything to do with the charging circuit. Plug and socket type connection do fail on poor connections. Check voltage on batteries when on charge and off charge to see if the charger voltage is getting through to the batteries.
hi, okay so you got a onboard charger ? right there should fuses fitted to either on of the three wires coming out of the charger ? unless the charger is itself is faulty ?
You must charge each battery individually with an automotive NON automatic style battery charger until each battery has at least 10 bolts each. The scooter charger cannot pull up a battery with less than 10 volts.
