Samsung YP-K3 MP3 Player Logo
Posted on Apr 22, 2010
I bought a new CD and tried putting the songs from the CD on to my MP3 player. I am able to transfer the files onto the device but when I turn on my Samsung YP-K3, the songs are not on there. Why do they not show up on my MP3 player but it shows that they synced?
Anonymous
Level 1:
New Friend:
  • Contributor 25 Answers
  • Posted on Apr 22, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
25
Questions
0
Helped
4473
Points
37
If you have windows media player then all you need to do is insert your YP-K3 into the computer then windows media player will show you a bunch of options for your MP3 click what ever suites you. Then rip the C.D to the windows media player. Then click and drag the songs if you want all of them click the first one press shift down on your keyboard then stop when you have all the songs you want then click and drag to the right hand side where it has your YP-K3
1helpful
I need some instructions on how play it
1. Use Windows Media Player to put songs on your Coby MP3 player. Download songs in MP3, WMA, or OGG format from a legal downloading website. If the file is not one of the previously mentioned files, you must download a converter to convert the file to one of the correct files that can be played on Windows Media Player. Rip a song from a CD by inserting the CD and then click on the option to "Rip" the song to your library. Some Coby MP3 players do not need Windows Media Player to add songs, so be sure to check your user manual to see if there is an even simpler method.
2. Connect your Coby MP3 player to your computer using the USB connector that came with your MP3 player. The player will show up under the "Devices" option on your Window Media Player application.
3. Click on the "Library" option to view all of the songs stored on your Windows Media Player library. You can drag the song to the MP3 player in the "Devices" section, or you can right-click on the song and choose the option to transfer the song. In the pop-up box choose your MP3 from the drop-down menu and then click on the "Transfer" button.
4. Right-click on the MP3 player in Windows Media Player and choose the "Eject" option. Disconnect your MP3 player from your computer and turn it on. The song will now be available on your MP3 player. Press the bottom button to play or pause the song.
5. Add videos and pictures to your Coby MP3 player if it supports those files. The process is similar to transferring audio files. Plug your MP3 player into your computer. Open the photo file on your computer and drag pictures into the player. You can create folders to organize the pictures.
tip
Connect MP3 Player To Computer and Transfer MP3 Songs From Computer To MP3...
To successfully transfer songs either MP3 or WMA files to your MP3 player follow these steps.
1) If your device came with a CD insert this into your computer and follow the on-screen instructions.
If the device has no CD most PCs will recognise the device and update the drivers automatically once you have connected it via USB cable.
2) Connect the device to the PC using USB cable. With many players this is the only means of charging the device.
3) On your computer go to 'Start' - 'My Computer' and you should see the device listed as a USB Mass Storage or Removable Disk.
4) Click and highlight the songs you want to transfer to the MP3 player. You can either drag and drop them directly into the USB Mass Storage Folder shown in Step 3 or you can right click the song file and select 'Send To' USB Mass Storage Device.
5) The songs are now on your MP3 player.
6) Disconnect the player from the USB cable. The player will take a moment to update and you can now play the songs on the player.
Note: In order to transfer music files from a CD these must first be converted to MP3 in order for the player to be able to play them. To do this you can use Windows Media Player to 'Rip' the songs onto your computer in MP3 format. From here use the steps above to transfer them onto the player.
If your MP3 player has video capability these files will need to be converted in to a format that the player can handle. To do this, use the software that came with the device on the CD or you may use a free converter like this one if the original software is lost.
Hope this Tip has helped.
Please do reflect this and indicate your rating using the Yes/No buttons below.
3helpful
Can't seem to transfer music files to my new MP610-2G
The cobyt player is completely incompatible with iTunes. If you have songs that are in mp3 format, you can use Windows Media Player to transfer the songs to your Coby. If your songs are already in AAC (iTunes) format, you can use a free program like Media Monkey to convert UNprotected AAC files to mp3 format so that they will be usable with your Coby. Media Monkey is not capable of converting protected files.
-Tha Mp3 Doctor
1helpful
2answers
Not playing songs/ transferring to MP3 player on Rhapsody.
You probably have to redownload the songs again. Forget about the pictures, this player is pretty buggy, it's not worth it.
MP4 won't download
Install the Philips Device Manager software and drivers from the product CD.
You then need to use the Windows Media Player, Sync function to transfer music tracks.
1helpful
3answers
My mp3 player won't let me put any song onto it
format the plaer again and use it..
format it from your system.. do a normal format.. not a quick format..
1helpful
M p 3 player
Instruction manual can be found by entering your model number at www.usasupport.philips.com
The device itself is not faulty. This is Microsoft's1.gif fault, not Philips'. Some of the songs may have Digital Rights Management (DRM) encoding that the SA6025 will not support. You can right click on the trouble music file, select "Properties," and select the License or Digital Right tab - look for the msg: This file is not copyright protected. Find out if the songs that CAN'T be transferred have this message. If so, then click on acquire digital rights (or some variant of that phrase). If the files tha CAN'T be transferred DO have Digital rights protection, then you must save the files in a different format that is stripped of DRM encryption.
There are a few possible answers:
1)Start simple - disconnect the GoGear from the computer - let it update - then reconnect it to the computer; if this fails, restart your computer and try syncing again
2)You need a firmware upgrade to make the device compatible with your computer: just open up Philips Device Manager (Start --> All Programs --> Philips) - if you don't see it, then re-run the installation CD or grab the "Device/Firmware Manager" from the Philips website; click on the update tab
3) The songs have Digital Rights Management (DRM) protection.Try re-downloading the songs without DRM protection.
4) The songs are in a format not recognized by the GoGear. The GoGear, for instance, will not take iTunes files b/c they are AAC format. With MP3 files, the player supports 32 –320kbps. With WMA: 5-192kbps with sampling rate 8.0kHz up to 44.1kHz. Right click the song file, and select "Save As", and then change the format of the song file. Or, redonwload, in the above-said format.
-Tha Mp3 Doctor
Sansa turns on but does NOT do anything!!! :0!!
Sounds like you have a few different problems, thankfully its easy to resolve. Run the recovery tool from the SanDisk website, select FORMAT when prompted. http://sandisk.com/assets/file/downloads/firmware/e200fw01.00.12.exe Best of Luck. (this only works with non Rhapsody devices, annotated by an 'R' or the word Rhapsody on back)
Songs will not transfer
Re-rip them in Mp3 format, and you will have no problem
Can't transfer songs onto my mp3 player
Some types of mp3 files won't transfer to Creative Zen players. Try re-encoding the files either again in mp3 or in wma and try importing them again.
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
