Mitsubishi WS-65809 65" Rear Projection Television Logo
Posted on Apr 22, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 65" mitsubishi television and have problem with half the screen. Half the screen is out of focus with the green color outlining images and letters. The other half of the screen is working fine. Thanks
Anonymous
Level 2:
  • Expert 81 Answers
  • Posted on Apr 22, 2010
Anonymous
Expert
Level 2:
Answers
81
Questions
Helped
52034
Points
161
Your convergence ics are bad
The left half of the picture has gotten blurry, with pink, green outlining what seems like 3 different pictures of the same thing. The left half works fine and the HD of direct TV is good on that side. I...
The tv have a problems known as a tv convergence pictures problems,it is dead.Tv set have any colors lines like R,G,B mis alingnments,have colors shadows pictures or a 3D pictures look alike?Yes,than the tv set convergence board it is dead to causes all these pictures problems.The tv set convergence board must have to be repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv set convergence board to solved the tv set covergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors.
Split colors on screen
Replace the two convergence Ics they are STK392-110 if your model is the 53FDX20B you can get replacement Ics with installation instructions at the following link.
http://servicemanuals.vstore.ca/
Color convergence problem
If you follow the instructions on the other thread, you should be able to resolve the problem. Try the simple stuff first. Resolder the pins of the convergence ICs and see if that alone resolves the problem. Sometimes that is all it takes.
Keep us posted.
Dan
Mitsubishi DLP 65 in half of screen is tinted yellow - 3 mth old
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD, DLP & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Green on screen
try to do it inside the board.
there are some adjustments except brightness and focusing..
try if you can ...
regards,
1helpful
3answers
Mitsubishi vs-7071 rear projection tv
hey i have had the same prob on my other tv .it was about 300 to get it fixed.if you havent allready fixed it and if your not to fare away,id like to buy the screen
Focus
Use the Setup menu to select English or Spanish as
the language for the menus and on-screen displays.
Adjust Color Balance Automatically or manually
(PerfectColor TM) using six colors, Magenta, Red, Yellow,
Green, Cyan and Blue. Reset the Color Balance to the
factory default settings. Align the focus (convergence)
of the TV's projected light beams or reset the focus to
the factory default settings.
Mitsubishi WS-65905 DTV is green
A compatibility issue rears its ugly head. The format that was to be back then has changed slightly over the years and this is what it's come to...Sorry...accordianman
2answers
Sony 65 Inch Projection TV Color Red Green Separation
Sounds like a convergence issue. Call Sony for an ASC that can come out and give you an estimate. You are probably looking at $200-400 to do the repair.
2answers
SONY 61" Rear Projection TV
you will need to get a service manual for the tv and enter the service mode. then you will need to readjust the convergence.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
