Cant sign in yahoo messenger
Restart your pc and try again........if you are using messenger 9.0 then click on <messenger> before sign in then click on <connections and preferences> and mark there an option <use no proxy> i hope that will be solved.
if this does not work then wait for sometime and then retry, this also happens if u shutdown messenger without logging out.
SOURCE: cannot sign in yahoo messenger
It may have 2 problems and 2 solutions:-
Firstly, this error occurs when your connection preferences are notproperly set. I'm not talking about your Yahoo! ID and Password here,but you may need to adjust certain features depending on what networkyou're on. Let's says for example, if a firewall protects your network,it may block yahoo messenger when it tries to connect to the server.You need to change your connection settings, click the Messenger menuin yahoo messenger and select Connection Preferences. Select FirewallWith No Proxies. Select your Internet Connection type from thepull-down menu at the bottom and enter your Home Country if theseoptions aren’t grayed out. Click OK and login again using the newsettings.If this option doesn’t work, click Connection Preferences inYahoo! Messenger again and select No Network Detection. Try to loginagain using the new settings. In some instances, you may need toprovide yahoo messenger with the IP address of your firewall or proxyserver (you can get this information from your network administrator orfrom your Internet service provider). Click Messenger and selectConnection Preferences again. Select Use Proxies. Enable either theHTTP Proxy or the SOCKS Proxy as needed and provide the proper address.Click OK and login again using the new settings.
Secondly, if you are using IM9 there are sign in problems. This is whatyahoo has to say.Try an updated version of Yahoo! Messenger 9.0(9.0.0.2128). This latest build includes a fix for the sign-in issuesthat have been affecting some users. If you were seeing an error code“81003005” when trying to sign in, this latest version may fix thatproblem. Even if you were experiencing a different kind of sign-inissue, I recommend installing this latest version.
Hope it can be helpful!
If you satisfied with this information, please do support me...
Thank You!
SOURCE: cant sign in in yahoo messenger!
If you are talking about error 81003004... just go to the icon "messenger" and then click "connection preference". Click the "connect directly to the internet" click this even though it is highlighted and then click apply and then OK. Hope this help for you.
SOURCE: my yahoo messenger cannot sign in
this is mujahed and i unable to login to my Yahoo ID. actullay i reset my yahoo password and after again i try to login with my New password. but its not working and i try too many time and my account gets locked. so i will try to get my password with option of FORGOT MY PASSWORD in that they ask me question like, where i spend my honey moon but i never mention any such information on yahoo and a part i mention the detail like i am unmarried. so kinldy do the needfull to get out this problem. thanks for your quick response and your more valuable suggest you can mail on my alternative ID. [email protected]
