Krups Small Appliances Espresso Machine Logo
Posted on Apr 22, 2010
I have a Krups Espresseria Automatic. All lights flash
4 lights flashing namely coffe grounds, calc, clean and tank flash together. Tried unplugging but doesn't stop it.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 01, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
2199
Points
The "calc" light on and pulse.
Krups Espresseria Automatic Premium machine repeatedly displays the following message "Filling of machine necessary".
You may find that whatever detects the water level is faulty. Normally there will be a magnet that floats in the side/back of the tank. If it's sitting on the bottom of the tank then try and shove something plastic between it and the bottom of the tank to lift it up. If that fixes it then you have a choice to leave it like that or buy a new tank.
How to stopp the leaking under the watertank?
Normally solved by replacing the tank seal where the tank plugs in.
1helpful
Grinder in Krups Espresseria EA8000 stops and whirrs.
Hi, i had similar problem on my Krups. Inner star plastic part which remove powdered coffee is maybe damaged. You need to replace or overhaul your grinder or you can replace inner star plastic part by yourself. Coffee grinder spare repair part plastic inner star Krups Mhle...
Saeco intuita- performed clac/ clean, and now calc/ clean fast flashes. Pressing only goes to slow flash and water dispensor light fast flashes.
Use a paper clip to clean the Needle that penetrates the Kcup. If it still happens call 1-866-901-2739 for direct assistance.
2answers
Intuita coffe machine not working
Needs a service take it in let them replace the seals,If the seals go faulty this happens
My coffee machine is flashing
That means that you need to clean it...
mix half white vinegar and water together...then pour this solution in just as you would if you were making coffe....minus the coffe grounds of course... then run it through a cycle and then run clear water through again... and you will be good to go...do this once a month or so to keep it working great...
heatman101
1helpful
2answers
Krups Espresseria Automic XP7200 coffee machine
As this is an automatic espresso machine, I suspect that the cake container is where the "used" pucks of ground coffee drop into after your espresso is extracted. The container may not be fully seated in position. See if there is a door on the machine that the container may be hiding behind.
Good Luck.
-Steve
Krups xp7420 espresseria automatic
am o proare 01 la un espesor krups 7220/7240
Top Krups Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Paul Carew
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
