Why does my portable air conditioner cool for a short period of time and then turn off?
Have you extended the exhaust hose with another? The unit can ONLY be used with the included exhaust hose (dryer type exhaust hoses will cause the unit to over heat).
How close is the unit to the wall? If the unit is only inches away from the wall and you are running the exhaust hose out a window, more than likely their exhaust hose bend is at 90 degrees which restricts air flow. In order for the unit to run more efficiently and not overheat, it should be at least 1-1/2 feet away from the wall and the exhaust hose should not exceed more then a 45 degree angle.
Are you exhausting the unit out a hole in the wall? If so, are you using a flap vent on the exterior of your home/office? The flap may be too rigid and not open continuously. The compressor is not strong enough to push the air through and therefore will only run for a short period of time before overheating and shutting off. You should take the flap off the vent and replace it with a piece of screening.
Are you venting it into a ceiling or basement? Does the ceiling or basement have ample ventilation? If the ceiling or basement does not have a way of pushing the heat from the exhaust to the outside, the unit will work for a short period of time and then eventually overheat and shut off.
Portable Air Conditioner FAQ Portable Air Conditioner Frequently Asked...
I've never used a ceramic chimney, or seen one for that matter. I know that the dual walled vent pipe works better when warn/hot. Can't explain it real well but the inner pipe gets hot while venting the heat and smoke. And between the inner and outer wall is cooler air, which is drawn down towards the wood burner. Creates a suction by the exhaust out of the center pipe. Mine smokes up the house when I leave the doors open and when it's a low flame inside. I'm sure you've checked on the manufacturers' specs for venting but, if you don't already know, look into the thermal dynamics of a dual walled vent pipe. And also a ceramic as you have. Has to be something with your stove install or vent pipe. Hope this couch advise helps!
Water in the drum anytime after drying a load of clothes is not normal.
Was the load prior to you having found the condensation fully dried? If not, check for lint in the vent system and make sure that air is coming out of the vent (the flap or louvers on the vent cap should open fully on a short vent line). Even so, this would not account for a small amount of standing water in the drum.
The first thing that came to mind was outside air being drawn in through the vent. If you have air conditioning and a well-sealed house, the warm, moist air hitting the cool drum (in a relatively dry atmosphere) may cause condensation. Check the outside vent to ensure that the vent cap flap (or louvers) is (are) closing all the way. Convection or air flow from the basement to a vent fan in an upper level might cause this.
What is in the room above the basement bathroom? And how large is the diameter of the vent pipe you need to run? Do you have a maximum number of elbows, and runs of feet maximum you can't exceed?
Is the Frame wall above the foundation, accessible by going up thru the ceiling of the bathroom, and the elbowing over and into the outrside frame wall at that point?-- and then up a ways, and then out thru the outside wall?
Another possibility would be: How far to a window, or vent already in the basement?-- Could you run the piping there, and then out?
How thick is the concrete wall?-- Is it reinforced Concrete-- or just Masonry Block wall? A block wall is not as hard to get thru--
I know I asked a lot of questions-- but maybe it helps you think thru your options?
My suggestion is to build up the floor where the tub will be maybe 12" above original floor and u can make a couple steps up to the tub the whole length of tub
It would be best in your circumstance to slope your vent like one might slope a drain. 35 feet is waaaaay too long, 20 feet is max, and you can deduct 6 feet for every bend. If you can reconfigure your vent to a sloped drain, this will help.
The coolness of the basement is a contributing factor, but normally, it doesn't figure into the issue.
If you cannot shorten your run, or slope your line, you might do well with a trap that would have a mini sump pump in it. These are available from A/C companies, and are automatic in their operation. I have had one in one of my units, and the cost wasn't unreasonable. You can probably find one on-line (EBay?)
Venting into the basement may resolve your water issue, but you still have to deal with the lint that "escapes" the lint trap. Most of it will likely wind up in the air conditioner, and all over whatever you have in your basement.
A mini sump sounds like your best option, even if you have to set up a schedule to clean it out occasionally.
Best regards, --W/D--
you answered your own question, its not producing to much miosture, its not releasing hte moisture with in the clothihng, Id be willing to bet that you have a MAJOR clog within the venting!!!!!!
ck vent hose behind dryer to be sure it's no mashed or crimped may be too close to wall then ck vent to outside too long or too many bends will reduce air flow to outside
