Toymax Magnavox 37MF331D 37 in. LCD TV Logo
Anonymous Posted on Apr 21, 2010
After a couple months or so of taking 15-20 minutes for the picture/sound to show up the set just died one day during viewing time and now won't turn on at all and nothing is blinking.
Chi Chu
Level 3:
  • Toymax Master 8,457 Answers
  • Posted on Apr 21, 2010
Chi Chu
Toymax Master
Level 3:
Answers
8457
Questions
0
Helped
2822518
Points
26282
Ur power supply board is dead.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.Will solved the power problems.
Testimonial: "thank you much - at least I won't be blindly looking for problems."
2answers
I have a 15 month old Samsung 65" TV UN65TU8000FXZA that stopped turning on and off.
It cold be the power supply is going bad for your TV and that the TV is starting to die on you guys and it would be more cheaper to buy a new TV than to try and repair the old TV that is no longer working anymore.
TV picture goes out after 10 minutes of viewing with popping sound
It can be a couple things. Something bad on the power board. Or the vertical output circuit. How long ago did you purchase the television. Your best course of action is to have it serviced.
If you need any information or other assistance let me know.
Thanks,
Lee
I have a double pol 208 dgm100 and i conect whith contactor and i cant able to program please can you help
Tork digital timers and manuals appears on following link
http://waterheatertimer.org/Tork-Digital-timers-and-manuals.html#DGM
DGM100 programming manual:
http://waterheatertimer.org/pdf/TORK.DGM100.INSTALL&OP.pdf
DGM100 is single channel timer, so timer operates all Loads at same time.
In other words, if you have 2 different contactors, the timer cannot set different schedules for each.
7-day programming
32 set points
Programming buttons:
1) When powering up the unit, model number 100P appears on screen.
LCD displays 12H which is an automatic (AM/PM) format.
Press ENTER to keep 12hour am pm -or- press HOUR to change to military time, and then press ENTER
2) Unit is in RUN mode and time displays.
3) Set current time:
Press DAY/Month key to select current Day.
Press HOUR key to set current hour (with AM/PM).
Press MIN key to set current minutes.
Press ENTER key to confirm.
Unit now stores present time. Seconds are set to zero.
4) Daylight savings time (DST) automatically adjusts for daylight savings time, if you choose this option.
In step 3 you set current time, but you did not set the Month and date.
YES DST: If you want DST then follow step 5 and enter Month and date.
NO DST: If you don't want DST, then skip Month and date, and move forward to step 6
5) Set month and date.
Press MODE until DATE displays
Press Month button to set current month
Press Date button to set current date
Press ENTER to confirm
6) Set programs
Press MODE key until SET displays
Display shows --:-- 01 which is program1
-Press DAY/MONTH key to set day(s) you want program1 to turn ON
Following are choices that display on screen:
MO to FR (MO, TU, WE, TH, FR)
SA and SU (SA, SU only)
MO to SA (MO, TU, WE, TH, FR, SA)
SU to SA (SU, MO, TU, WE, TH, FR, SA)
Individual days: SU, MO, TU, WE, TH, FR, SA, and D
for Special Day (usually a holiday).
-Press HOUR key to set hour {check AM/PM} you want program1 to turn ON.
-Press MIN key to set minutes you want program1 to turn ON.
-Press ON/OFF button to select ON, and then program1 will turn ON at your set schedule.
Press ENTER to confirm setting.
Display now shows --:-- 02 which is Program2
-Press DAY/MONTH key to set day(s) you want program2 to turn OFF
Choose same days you chose for Program1 ON so timer does not have conflicting programs.
-Press HOUR key to set hour {check AM/PM} you want program2 to turn OFF
-Press MIN key to set minutes you want program2 to turn OFF
-Press ON/OFF button to select OFF, and then program2 will turn OFF at your set schedule.
Continue setting up to 32 different programs.
When finished programming, press MODE button until RUN appears
Manual shows more programming options such as override, reviewing programs, setting special days.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer.
3helpful
My Sony Trinitron 36'' model#: kv32v26 is taking a long time to show picture when turned on. The sound comes on and the red light blinks for about 3-5 min. before the picture turns on. And when i switch to...
Hi Matt.
I`ve been repairing sony tv`s for a long time now and i can tell you that what you described is sure signs of a weak picture tube.
And the price of a new picture tube makes it prohibitive to replace it. You could open the set and adjust the screen control on the high voltage transformer but it won`t last long. If you decide to do that , look for a transformer with a long and thick red wire that connects to the back of the picture tube , That is the flyback transformer and there will be two controls on it, you want to adjust the bottom control that is the screen control(the upper one is the focus).
Turn your tv on and slowly turn the screen control up until the picture shows up at a reasonable brightness level, if yout turn it to high or you may get retrace lines in the picture.
That may strech the life of your set for a couple of months .
Hope this will help. Merry Christmas
I have a Nikon D80 with an 18-135mmNikkor lens.  It's about two months old.   Yesterday I was outside, on a snowy day,and a couple of times, I pressed the shutter release button and it would not take a...
i suggest pointing the camera to an image which has more contrast as opposed to pointing it into a clear blue sky which has no clouds at all. the AF might have some trouble looking for cue to focus. go manual focusing and see the difference.
No picture on my Dell 790 monitor (17
Tom,
What you've got it a busted backlight inverter... need to replaced a new one or repaired it. To repaired, if you are lucky just replaced a couple of faulty capacitors in the power supply w/ built-in inverter... Good lucks, have nice day!
No image but good quality speaker.
Sony has had a problem in older sets with-believe it or not- lack of humidity. I had one with the same problem. If it is under warentee take it back, if not-I know it sounds insane- put a large plastic garbage bag over the turned off set. Leave it that way for a couple of days. do not turn it on during this time. After a couple of days remove the bag and turn it on. If it works-that's the problem, if it doesn't- it's dying, and to expensive to fix. Surprised the heck outta' me when I tried it on my old Sony 19" set- it worked.
Image not visible on monitor screen
My viewing screen is black. I had successfully taken a picture, viewed it, and turned the camera off. When I turned it back on about 30 seconds later, the viewing sceen was black. I can 'take' a picure, but it comes out black. Help!
Top Toymax Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Are you a Toymax Televison and Video Expert? Answer questions, earn points and help others
