Basically I have the replacement part... before I just pull the seal out and try and push a new one in - I want to know if I am missing out on some clever trick?
Just take your coffee maker apart and look under the top part. You'll see the seal and the metal filter. They are only held there by the friction of the seal itself (and any crud that might have built up by now). So with your finger nail or a butter knife pull out the seal, and with it will come the metal filter. It's not a bad idea to do this every time you clean your maker anyway. To replace with old or new seal, just put it back in place: first metal filter, then seal. Easy as can be.
Check the coffee funnel for any dents around the edge of the funnel. Normally if this brewing problem happens after changing a gasket the problem is a dent or the funnel is out of round and the new gasket isn't formed to it like the old gasket was. Don't bang the funnel to get grounds out or it may dent or get out of round. Try pulling the funnel over to one side in the water chamber and if you see a space on one side pull it tight with the other finger to bend back into shape if possible or replace the part.
Take the gasket and filter plate out from under the upper unit and hold the filter plate up to the light to check for any clogs right in the center where the coffee brews up. You should be able to see through all the holes in the filter, brush clean if needed
