You need to forward these ports on both your router, and computer aswell as firewall you got one of those.
Port 88 (UDP)
Port 3074 (UDP and TCP)
Port 53 (UDP and TCP)
Port 80 (TCP)
You might aswell need to open 1863 (UDP and TCP) if you want to use video chat for the kinect. Listed ports need to be forwarded when connecting to XBOX Live A more detailed guide to setting it up is available here: http://support.xbox.com/en-us/xbox-360/networking/network-ports-used-xbox-live
Before you
connect any cables, turn off your router, modem, PC, and Xbox 360
console. (Unplug your modem from its power source to turn it off.)
Connect one end of an Ethernet cable to the Ethernet port on your modem
and the other end to the Ethernet input port on the back of your
router.
With another Ethernet cable, connect one end to one
of the router's Ethernet output ports. Connect the other end to your
PC's Ethernet port.
With the third Ethernet cable, connect
one end to another of the router's Ethernet output ports. Connect the
other end to the Ethernet port on the back of the Xbox 360 console.
Turn on your modem, then your router, then your PC.
Make sure your PC can access the Internet. If not, you may need to
configure the router for Internet access. For help configuring the
router using your PC, check the instructions that came with the router.
Turn on your Xbox 360 console and sign in with your profile.
If this is the first time you've turned on your Xbox 360 console, see Create Your Gamer Profile to get started with both the Xbox 360 system and Xbox LIVE play.
If you're unable to connect to Xbox LIVE, you can try to diagnose the problem right on your console. Go to My Xbox and open System Settings, then select Network Settings (setup XBOX using Automatic Configuration DHCP), Test Xbox LIVE Connection.
I had the same problem when i started 3 years ago. now i recently bought the new wireless adaptor and have one of the new routers from eircom and after 20 minutes during gameplay it disconnects me from xbox live.it is really startin 2 annoy me now. does anyone know what could be causing this to happen??
make sure that your xbox is acctually getting an ip address, by default it should be a 192.168.0.xx number and the gateway should be 192.168.0.254 If however your xbox tells you that its ip address is 168.xx.xx.xx (a private ip address) or if it is simply 0.0.0.0 it would sugest a cabling problem. However if the network troubleshooter finds no faults and you are still unable to get into xbox live try setting up a PPPoE connection using the username eircom and broadband1.
Alternatively,If you click on Firewall in the Netopia admin page, and set the security level to Low, xbox live would suddenly start to work.
******Also add UDP ports 88 and 3074 if nothing works.On a netopia 3347 you can get this option in the NAT option.U have to enter the port numbers and the service name(xbox).
Hope it works for you.
Firstly... avoid showing your SSID (eircom-123456789) here, as the WEP key can be reverse engineered from the SSID.
To change your SSID, connect your router to your PC with an ethernet
cable, go to your web browser (Intenet Explorer, Forefox, etc) and type
192.168.1.254, and press return.
This will open the control panel for the router.
Select 'EXPERT MODE' from the menu on the right, and accept the warning
prompt. Then click on 'CONNECTION' and the 'WIRELESS' on the menu on
the right.
In the main window you can then change the SSID for your network.
You can also change some of the other options in this window such as
enabling closed mode, change security protocol, password, etc.
Netopia's Modem my also act as a Router protecting your system from internet traffic! You need to check your model to insure what you have. If it is a Router you will have to Contact Netopia in regards to configuring Pin Hole on the Router to open the gaming ports on the Router.
