You can turn on the keypad lock of a handset.
In idle mode, press * button and then LOCK to turn on the keypad lock. "PRESS UNLOCK TO USE KEYS" is displayed on the LCD.
In keypad lock mode, press UNLOCK to turn off the keypad lock.
My keypad won't light up when door is locked when you push lock won't light up green:
To make the keys light up when you want to enter your code, you have to push the lock button on the keypad first. If the keypad light never comes on, open the door and manually lock the interior lock, then press the keypad lock button. The above instructions should then work.
Keypad lock To prevent accidental key presses,
select Menu,
and press * within 3.5 seconds to lock the keypad. To unlock the keypad, select Unlock, and press * within 1.5 seconds. If the security keyguard is on, enter the
security code when requested. To set the keypad to lock
automatically after a preset time when the phone is in the standby mode, select Menu >
Settings > Phone > Automatic
keyguard > On. To answer a call when the keypad is
locked, press the call key. When you end or reject the call, the keypad locks
automatically. When the device or keypad is locked,
calls may be possible to the official emergency number programmed into your device.
1.5 seconds. If Security keyguard is set to on, enter
the security code if requested.
To answer a call when the keypad is locked, press the
automatically locks
You
can manually lock the keypad to avoid pressing keys by accident. You
can still answer an incoming call and the keypad will lock again when
the call is finished. The keypad remains locked until you unlock it
manually. Depending on your phone model, you can activate the
automatic keylock. When the automatic keylock is activated, the keypad
locks shortly after you stop pressing keys. Please note: with
some phones you can still use external keys when the keypad is locked.
If you wish to lock the external keys you must lock them separately.
You can manually lock the keypad to avoid pressing keys by accident. You can still answer an incoming call and the keypad will lock again when the call is finished. The keypad remains locked until you unlock it manually.
Depending on your phone model, you can activate the automatic keylock. When the automatic keylock is activated, the keypad locks shortly after you stop pressing keys.
Please note: with some phones you can still use external keys when the keypad is locked. If you wish to lock the external keys you must lock them separately.
