Zebra 140XiIII Plus Thermal Label Printer Logo
Posted on Apr 21, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Z140XiIII that used to have a ribbon and thermal transfer stock. we changed the stock to not require a ribbon, so we removed the ribbon and set the menu to Thermal direct. labels print OK but the error light flashes and the ''Ribbon In'' error keeps displaying. The transition to ribbon-less printing went fine on a Zebra 220XiIII.
Anonymous
Level 2:
Scholar:
  • Expert 97 Answers
  • Posted on Apr 21, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
97
Questions
0
Helped
89049
Points
255
If the printer is flashing "Ribbon in" then it sounds like the printer setting to Thermal Direct is being changed back to Thermal Trans. Verify this after sending a format. This is very common because the printer is bring over-ridden by the software and/or printer driver when you send a format.
Look for a setting in the software / driver for direct thermal and make the change there.
Hope that helps.
Bar code printed on sato m5900 Rve printer will not scan. Same bar code printed on HP laser WILL scan. Font used is ID Automation 39 - prints at 6 pitch
Are you printing in thermal transfer mode or on thermal direct stock? Sounds like your image is not black enough for your scanner. Things to check: adjust printhead temperature, change ribbon stock, change thermal-direct stock, adjust scanner's sensitivity.
I am having a problem with the wax ribbon smearing on a thermal label after I imprint on it. Is going to a resin/wax ribbon the only answer?
Not necessarily. It could be a head adjustment. If you are just printing on a blank thermal transfer label stock then wax should be just fine. If you are printing on a colored stock then a resin/wax would be better. We use resin/wax on everything because it is the same cost and runs better. But if you have only blank paper wax will be fine. If you are smearing then I suggest adjusting your head. Even if it printed fine before as your platen roller wears down it will require slight head adjustments to print properly
2answers
I have a few Datamax-I-4206 printers and some of them have the Thermal Transfer ribbons and some do not....Do I need to have Thermal Transfers or cant I just print to them without it?
If the unit is set up for either(with the thermal trasnfer option- ribbon unwind and rewind assembly) you can use either ribbon- with thermal transfer stock, or direct thermal- with direct stock.
You can tell the stock by rubbing something across the stock to see if it will turn black, that is direct thermal stock.
If using direct, go into the setup and select media type- direct thermal.
If using ribbon- use thermal trasnfer option. But remember to install ribbon before calibration as ithe printer will error on out-of -ribbon.
In the barcode printer showing ribbon out. I change the print method from " THERMAL TRANSFER TO DIRECT TO DIRECT THERMAL " and saved. Again come the same problem RIBBON OUT. How I solve the problem....
You need to change the print method from thermal transfer to direct thermal. There are three places to do this:
- on the printer itself - in the printer driver (this will override the setting in the printer and be the default setting for any new labels crested) - in the print properties of a specific label (this will override the two settings previously listed) The last option works best if you are switching label stock or ribbon in and out for different labels.
2helpful
Warning Ribbon in
If you're trying to print using Direct Thermal and you have a ribbon installed, the sensor will set off that alarm.
If you WANT to print using direct thermal, remove the ribbon.
If you want to print using ribbons change the Print Method in your front panel setup to THERMAL TRANSFER.
4helpful
Ribbon spool does not turn, TEC B452
If you are working with the driver, change in stock page direct thermal to thermal transfer.
4helpful
3answers
ZM400 printer
Try going through the LCD menu and if it say "Direct Thermal" change it to "Thermal Transfer", Direct Thermal made means, no ribbon required, but it sounds like you do have ribbon in the printer, if so, try my recommendation. If it asks for a password, it's '1234'.
How to say to the priter we don´t use ribbon
If you are printing in direct thermal mode (without a ribbon):
· Check your software settings and make sure that the print type is 'direct thermal'. If your software package requires the use of a Windows driver, also make sure that the driver is set for direct thermal printing.
If you are printing in thermal transfer mode (with a ribbon):
· Check your software settings and make sure that the print type is 'thermal transfer'. If your software package requires the use of a Windows driver, also make sure that the driver is set for thermal
transfer printing.
Check to see if there is any dirt on the ribbon spindle gears or on the ribbon motors. For the latter
you will need to remove the electronics cover. If there is dirt in either of these areas, try vacuuming around the motors and/or the spindles to remove as much of the dirt as possible.
Top Zebra Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
ExpressFiX
ExpressFiX
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
