E36 bmw 318 1991
check fuse?
relay of fuel pump?(in the separate box beside the fuse box?
is the current on fuel pump?under seat in back,right side,take of cover,black,find connector with biggest wiring,other with fine cable is fuel meter,
with back seat away and cover open,when starting,no doupt,you should hear the pump,
if all ok,
check ignition coils,but,it would seem bizarre they all four brake down in one shot,
fuse box,check power,
and....also check relay under stering wheel,is fo alarm,but...aso happens....
good luck...
