Best way to locate and repair a slow leak in a intex seahawk 500 inflatable
Get some bubble bath, mr. bubble, or just dish soap, thinned out with water, spray it all over the boat, you will get it cleaned up and find the leak at the same time. When you see th e stream of bubbles coming out, mark it, get it dried off and patch it up. I think they use a contac cement on the Hypolon boats, or is it neoprene? Do you have a patch kit? Any pieces of material for a patch? The hardware store has pvc rubber used for shower pans, that might stick on there, clean it good with laq thinner, and brush on some glue, both pieces, let dry, then slap them together. You will know if it will work. Or else look up the manufacturers recommendations. he boat supply might have patch kits in stock. Hope this helps.
