Check the fuel solenoid is getting power. It may be locked out by loow lube oil pressure and other things.
ALSO when restarting a diesel one OFTEN must "bleed" the fuel lines at each injector... same as when one inadvertently runs a diesel out of fuel. Crack the connectors at the injectors and crank till fuel comes out and tighten each one. Yes, it is a pain...
Check the pump solonoid by supply it with current directly from the battery with a cable watch out for the voltage of the battery.If it is 12volt use a 12volt battery while if it is 24volt use a 24volt battery
Does your Perkins generator fuel injector is burning? Have you checked that? The injector atomizes the diesel fuel and sprays it into the combustion chamber. The injector consists mainly of the nozzle and nozzle holder.
If it is fuel injector problems, you can check the problems below:
1. Long time idling operation
2. The fuel is not clean
3. Fuel injection time is too late
4. Improper assembly
5. Improper use of generator set
You can get some helps from the following articles:
https://www.dieselgeneratortech.com/diesel-generators/reasons-for-fuel-injector-burning.html
https://www.dieselgeneratortech.com/diesel-engines/Engine-Governor-Fault-And-Fuel-Injector-Fault.html
The diesel generator set first puts the stuck fuel injector into diesel or oil, then takes it out and wraps it in the cloth, then clamps the needle valve. The pliers move slowly. Remove the needle valve from the needle valve body, and drop a small amount of cleaning oil in the needle valve body to repeatedly move the needle valve in the needle valve body until the needle valve moves freely in the needle valve body, such as the burn surface of the needle valve. The abrasive paste should be used for grinding. When grinding, pay attention to the amount of grinding paste and grinding time. Install the cleaned valve valve connector on the injector and adjust the injection pressure for reuse.
Check the selinoid but short cicuting it , if ok
check if diseal goes to the engine by oening injector pipe and pumping fuel
if fuel goes ok try to ut som carb cleaner in the air filter and run if it runs the pun head is worned and you must fix it
