JVC GR-DVL300 Mini DV Digital Camcorder Logo
Posted on Apr 21, 2010
JVC GR-DVL100 camcorder fault showing "E04 Unit in safe mode remove and reattach battery". Any ideas?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 19, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2041
Points
5
E04
remove and reattach battery,
Unit in safeguard mode.
1helpful
When i switch on my JVC GRDVX9 it says on the screen E04 unit in safe guard mode remove and reattach battery
Following are the solutions:<br /> 1. Through your camera in dustbin;<br /> 2. crush it with hammer <br /> 3. Put it on fire
2answers
I'm getting an E04 ( error) when I try to record or play
Here is some information regarding the E04 error message from http://www.techlore.com/article/10974/JVC-Camcorder-Stuck-in-Safe-Mode/:
"JVC notes that you are also given a malfunction code when the unit is placed into safeguard. If it displays code 01, 02, or 06 you should remove
the battery and powersupply and wait for a while. Code 03 and 04 indicate that you should eject and reinsert the tape.
If neither of these solutions work, your only alternative is to bring it to a shop or send it to JVC for diagnosis or repair. Unfortunately, there is no other way to clear the condition."
This doesn't seem uncommon, and indicates a bad tape is loaded, or unfortunately, that the camcorder requires servicing.
10helpful
2answers
Shows fault E04 remove & reattach battery
Do a search of this problem and you will ind that every JVC owner is having the same problem. I finally got mine "reset" by powering the unit on in payback mode while holding down the "play" button. Then, turn it back off and power it on in the camera mode while holding down the "rec" button. This seems to have reset it and I've not had anymore issues SO FAR!
Good luck with it.
Hi, Regarding the above fault with my JVC camcorder, I have solved the problem by removing the tape and replacing with a new one. Thanks anyway.
Regards,
**** Coupe
JVC GR-AXM18U Compact VHS Camcorder
perhaps you should turn off the camcorder, remove the battery, wait a minute, and then put it back in.
JVC GR-DVX90
Put it on fire and buy some good camcoder<br />
3helpful
E04
Here's what i found. I was able to clear the message by opening and closing and ejecting the cassette. I also had to play with the battery at the same time. Keeping the cassette door open and then pulling out the battery. After is did this a couple of times i got the message to clear. I too haven't used my camcorder for some time and now that the error message has cleared the camcorder tells me that i need to clean the heads. Hope this helps. Below is the message i found that pointed me toward ejecting the cassette. An error indication (E03 or E04) appears. - (E03 or E04 UNIT IN SAFEGUARD MODE REMOVE AND REATTACH BATTERY) This massage a malfunction of some kind has occurred. In this case the camcorder's functions become unusable. - Eject the cassette once and re-insert it, then check if the indication clears. When it does, you can resume using the camcorder. If the indication remains, consult your nearest JVC dealer or service center
1helpful
E04 Error Message
Here's what i found. I was able to clear the message by opening and closing and ejecting the cassette. I also had to play with the battery at the same time. Keeping the cassette door open and then pulling out the battery. After is did this a couple of times i got the message to clear. I too haven't used my camcorder for some time and now that the error message has cleared the camcorder tells me that i need to clean the heads. Hope this helps. Below is the message i found that pointed me toward ejecting the cassette. Good Luck, i'm off to buy a tape head cleaning cassette. An error indication (E03 or E04) appears. - (E03 or E04 UNIT IN SAFEGUARD MODE REMOVE AND REATTACH BATTERY) This massage a malfunction of some kind has occurred. In this case the camcorder's functions become unusable. - Eject the cassette once and re-insert it, then check if the indication clears. When it does, you can resume using the camcorder. If the indication remains, consult your nearest JVC dealer or service center
3helpful
2answers
Problem with JVC Mini-DV Recorder - Model GR-DVL100
This is a common failure with this generation of JVC. The E04 indicates a failed data communication form the head drum with the micro. It most frequently is resolved by solder rework of the drum fpc cable connector on the appropriate board. Not a job for an amateur. Good luck, magic seadog
Top JVC Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
