SOURCE: 1999 Mercedes-Benz S500
Hello, This is a fairly common problem for Mercedes. You can try to lubricate the switch with a graphite powder for locks that you can find in almost any auto parts store. Spray the powder into the lock cylinder and work the key in and out of the switch, then try to turn. Do Not Use Any Sprays Like WD-40 etc. If this does not work, order a new key from Mercedes, and try again. If you do get it turn, make sure that you can get the car to someone to remove the lock cylinder because it will do it again! If you can't get it to turn, you will need to take it to someone that knows these cars for repair. It is an expensive repair and you don't want just anybody to do the job.
I hope this helped.
CYA, Gator241
SOURCE: replacing the battery in a 2001 mercedes benz
Battery base has a device that clamps the battery on a step/notch on the side. Use a ratchet with an extension to loosen. Once it is loose you can remove the battery.
SOURCE: Merces Benz s500, Ignition key does not turn, can
Check Battery in car(make sure is not weak or dying), check battery in remote fob, possiable draw in system possiable fuse or possiable keyless entry module failure
