Whirlpool Duet GHW9150P Front Load Washer Logo
Posted on Apr 21, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When the washer is washing a code F20 will flash
I just bought this washer in november and am having problem with in any wash mode a code F20 comes up
Anonymous
Level 2:
  • Expert 523 Answers
  • Posted on Apr 21, 2010
Anonymous
Expert
Level 2:
Answers
523
Questions
Helped
134562
Points
944
Take the top of the washer off there is a book in there that will tell you what f-20 is
Miele Washing Machine. How can I get F20 Error fixed please? It says F20 and is beeping.
Question edited for clarity.
A Miele Washer F20 error code generally means that the drain pump filter is clogged and needs to be cleaned.
Miele Washer F20 - Troubleshooting Guide - HowToFixit.Net
Videos as well
https://www.google.com/search?q=miele+washer+error+code+f20
Washer will not complete cycle sends F20 code
he f20 (or fh) error code on a Whirlpool Front Load Washer is an indication of a water supply issue. To remove the f20 error code from the display panel, press Pause/Cancel 2 times. If that did not clear the error code, see below for what may be wrong
heres a link...https://removeandreplace.com/2016/01/12/whirlpool-washer-error-code-f20-troubleshooting-front-load-washing-machine/
Whirlpool washer is giving an error code f20. I have done all of the troubleshooting in the manual and some online but still getting the code. what am I missing?
Whirlpool Washer Error Code F20 Troubleshooting Front Load Washing Machine
This link will probably not help you ... but it does reinforce that many people have the same problem of trying numerous things ... but the code keeps coming back ... sounds very frustrating when you are trying to troubleshoot the issue yourself...
F20 machine won't stop
Whirlpool error code F20 appears when no water is detected entering the machine or if the pressure switch trip is not detected. The pressure switch is the part of the machine that monitors high water pressure. The washing machine automatically cancels the wash cycle during an F20 error. Wonder if it has additional issue since it won’t stop quality Appliance repair Stuart Internet answer.
F20 code comes on
recheck water supply. try different wash cycles see if you have same problem.
1helpful
What does it mean when my duet washer flashes F20?
F20 is a No Water Detect error.
It is an indication that you either have no water coming into the washer, or very little water at all. If the pressure switch has not tripped after 6 minutes, the error code is displayed. This can be a potential problem with the following:
* If you have NO water in the wash tub, check the following:
- Inlet water valve may be clogged. Clean inlet screens if necessary.
- Make sure water taps are on.
- Check inlet hoses for kinks or clogs.
* If you HAVE water filling the wash tub, check the following:
- Make sure you don't have a siphoning problem. Click the following link for instructions: Duet_Service_F20_error
Hope helps.
What does the F20 flashing code mean on whirlpool duet washer
I believe F20 may point towards a control unit failure.
You could try disconnecting it from the mains supply for a minute and plug it back in.
Hope this helps
When washing stops and flashes f20
That code means "No water or Insufficient water supply" Check the water supply valve, the fill hose screen for debris... Good luck let me know if that solved it..
2helpful
F20 error code no water coming into kenmore he3t washer
The following provided by fixya has the solution to error F20.
Click here for detailing on F20 Error
Good luck and please do rate my answer.
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
