My n73 says "memory full. delete some data." so i checked my phone memory. then there, it says my memory in use is 47mb. then my free memory is 162kb. 4kb in calendar, 8kb in contacts(but my contacts is empty) 25kb in messages(but my inbox is empty also and there's only 4 messages stored in my folders) 0kb in images, sound files, applications and video clips..then 117kb in documents. what should i do?
need some help here. tnx!
Press the following code and your problem will be solved
*#7370#
it will clean all your phone memory but not the original software
Goto menu messages option settings other ..
you can see memory in use..change it from phone memory to memory card
just format the phone using code *#7370# all the data will be cleared .
if the data is important to you, dont for get to take a backup before you format.
*#7370# i folowed this step but my phone asking me lock code ? wht is this ? please help me
but where do u type in the code *#7370#?
I had this exact same problem.
Turn the phone off. Take the battery out (completely remove it). Wait 10 seconds. Put the battery back, and boot up your phone.
The problem should now be gone .. thx .. :)
It might happen because there are apps that are open and not in use, close those open apps. or just restart your phone and kept pressing pen key upon startup.
reformat your phone also give a better solution.. by dialing *#7370# or *#7778# locked code will be prompted.
You could purchase an 512Mb, 1GB, 2GB, etc... "MMC" memory card and insert into the memory card slot on your Nokia N73, or delete photos, music, ring tones and/or video that you may have stored in your phones internal memory.
As for the the 162kb you want accounted for, it's not enough space for a lot of ring tones or a picture or two, so I wouldn't be concerned with that in comparison to the 47MB of memory being used. Note: 1 kilobyte (Kb) = 1 thousand bytes, 1 megabyte (MB) = 1 million bytes,
1 gigabyte (GB) = 1 billion bytes.
Find your solution from the list,
Nokia N73
Codes:
Software & Hardware Problems
Find Solutions for other Nokia Phones:
Nokia N95
Nokia N70
Nokia 6300
Nokia 6600
All the other Nokia Phones.
Leo privacy is small in mobile phone,locks apps and boosts the phone and have many other features,the best application I ever downloaded and also good for low ramed phones.Very efficient, really keeps snoopers out... LEO Privacy Applock Boost Hide Android Apps on Google Play
This is caused to lifeblog
take lifebolg>settings>and uncheck all
Thats all.
your phone is free now
Try my method, it is the lifeblog problem. Hope it help.
http://n73diary.blogspot.com/2009/12/how-to-solve-n73-memory-full-delete.html
SOURCE: Apr 14, 2009- my n73 says
sometimes when you delete some data it won't delete permanently so it will stuck in the memory, also some application do same. So the best thing to do is to format your phone to empty the phone memory only.
Keep in mind all data on phone memory will be lost so you can take a backup to be able to restor it again some time later.
i have 4SD/4GB memory card... i stored musics but when i check the attributes ,stored datas are gone. when i stored again music which is KB's capacity only, it say's full already..please help me..what will i do..
my n73 says "memory full. delete some data." so i checked my phone
i have the same prob wat do i do
yes please give me some solution
but with n81 8gb
hi help me
My N73 can't format *#7370# or *#7778#
my n 73 says memory full
but no data in phone memori and card is also have 1gb out of 2 gb
my n73 says "memory full. delete some data." so i checked my phone memory. then there, it says my memory in use is 47mb. then my free memory is 162kb. 4kb in calendar, 8kb in contacts(but my contacts is empty) 25kb in messages(but my inbox is empty also and there's only 4 messages stored in my folders) 0kb in images, sound files, applications and video clips..then 117kb in documents. what should i do?
i.e is yr mamory is full delete some data.
to the colution given by amat_jot: it will not interupted the memory card if you will do this solution?
my contacts were move on phone memory but when you go to see it its empty
